hi ,
all of my video collection are xvid .avi files .
those encoded using autogk can play without problems with "vlc" and "media player classic" .
but others which are downloaded from youtube and encoded using videoget software can only be played using "vlc" and i can't play them using "media player classic" .
please help i want to play them using "media player claasic" to use "save thumbnails feature " .
thanks .
this message appears in "media player claasic"
C:\Documents and Settings\a\My Documents\My Downloaded Video\Michel Gondry Solves a Rubiks Cube with his Nose.avi::Output
Media Type 0:
Unknown
AM_MEDIA_TYPE:
majortype: MEDIATYPE_Stream {E436EB83-524F-11CE-9F53-0020AF0BA770}
subtype: MEDIASUBTYPE_Avi {E436EB88-524F-11CE-9F53-0020AF0BA770}
formattype: TIME_FORMAT_NONE {00000000-0000-0000-0000-000000000000}
bFixedSizeSamples: 1
bTemporalCompression: 0
lSampleSize: 1
cbFormat: 0
Media Type 1:
Unknown
AM_MEDIA_TYPE:
subtype: TIME_FORMAT_NONE {00000000-0000-0000-0000-000000000000}
lSampleSize: 1
cbFormat: 0
Results 1 to 15 of 15
identify the video and audio codec with gstpot and post the details in this topic.
hi Baldrick ,
audio coded : 0x0055 MPEG-1 Layer 3 , 44100Hz 128 kb/s tot , Joint Stereo
video codec : xvid , XviD ISO MPEG-4
the others which work fine are : XVID, XviD 1.0.1
Uninstall the xvid codec and install the latest version? Also, make sure Xvid's support for other fourccs is enabled (decoderconfig dialog).
[quote="jagabo"]Uninstall the xvid codec and install the latest version? Also, make sure Xvid's support for other fourccs is enabled (decoderconfig dialog).[/quote
done exaactly what u said , didn't work though
Just use the VLC media player instead.
I bet you that VLC will work !
- John "FulciLives" Coleman
P.S.
OK I just read the entire post so ... what can I say? ... I obviously didn't read the whole post the first time. Still though ... be happy any XviD you have downloaded even plays at all. So you can't use MPC? Big deal *shrug*"The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
Check Xvid's Output Colourspace setting. "No Force" is usually best but try the others.
Verify that you file is really an AVI file. It may be something else, like an MP4 file, that's been renamed AVI. GSpot will report the container. It should be AVI or Open DML (AVI 2.0).
hiOriginally Posted by jagabo
i tried to play with Xvid's Output Colourspace setting , didn't work .
and yes it says avi 1.0 on gspot , so it's an avi file .
another question is it possible to send you the link of the videoget software which downloads youtube clips and converts them to avi , so u can try it yourself ?
Sure, I'll try it out.Originally Posted by bugsbunny14
here it is
http://nuclear-coffee.com/videoget/V...ller_trial.exe
thanks for ur help .
After downloading a video with that program use AVI FourCC Code Changer to change the "Four CC Used code" from "xvid" to "XVID".
first mine is not called AVI FourCC Code Changer it's called nick's FourCC Code Changer .Originally Posted by jagabo
and i did what u told me to do but unfortunately didn't work .
Make sure the top one is "xvid" and the bottom one is "XVID". Worked for me.
thanks alot jagabo for ur great help .
unfortunately it didn't work but at least i can play it with vlc which is good .
thanks again .
Media Player Classic can't play TS files
By Mylo in forum Software PlayingReplies: 14Last Post: 8th Mar 2012, 04:26 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 01:27 -
Media player Classic won't let me "navigate" using mkv files
By FatalX in forum Software PlayingReplies: 0Last Post: 20th Jul 2010, 20:51 -
What DivX standalone players play "BRRip.XviD" files?
By Stealth3si in forum DVD & Blu-ray PlayersReplies: 8Last Post: 10th May 2009, 21:14 -
Media Player Classic can no play DivX files
By siluet in forum Software PlayingReplies: 6Last Post: 30th Sep 2008, 15:46
