VideoHelp.com Forum
    Hello All...
    I am trying to make an iMovie of my clips from a vacation, first time using the camera and first time using a Mac.
    I can easily convert the movies to high quality DV, but it "shrinks" the video down to 640x480 and I don't know how to force it into 720x480.
    If I convert via another codec, I get the 720x480 but the quality is much lower.
    I'm using ffmpegx, and I've tried dvdrop - exact same results. I'm sure the video is widescreen because the source mpeg is identified as 720x480, and looks just wrong in 640x480 mode
    note: what's even weirder, is that in the ffmpegx status section, it says that it IS encoding to 720x480. What gives?
    Your DV files probably are 720x480 (640x480 isn't even legal for DV) and the display software is displaying at 640x480 because it "knows" DV is 4:3, not 3:2.
  3. Member edDV's Avatar
    For DV format, 720x480 is used for both 4:3 and 16:9 (wide) aspect video. The only difference is pixel aspect ratio and the wide flag.
    When the 720x480 is viewed as square pixels, 4:3 video will appear slightly wide and 16:9 will look tall and thin. Square pixel display from a video player for 4:3 is 640x480 and ~854x480 for 16:9 (wide flag). If the video is 16:9 and the wide flag is missing, the video will be displayed as 640x480 and the video will appear very tall and narrow.
    Whats extremely weird is that one, and only one, of the videos DID convert into wide screen. Funny...
    For now I'll settle for mp4, just because I wanna try out iMovie. But any further help... maybe things I'm missing, what not, would be appreciated.
    THANKS!
  5. Member edDV's Avatar
    Nothing unique about DV format. The same issues apply to DVD MPeg2, SD ATSC and SD DVB. Mpeg 4 (h.264 and VC1) at SD resolutions have the same PAR issues unless you retreat into SD square pixel or jump to HD. 1280x720 and 1920x1080 are square pixel formats but most HD recording formats (e.g. HDV, HDCAM, DVCPro, etc.) use non-square pixels as do most plasma HDTV sets.
    They do this to increase picture quality for a given bitrate or display technology.
  1. How to fix aspect ratio value without video conversion
    By roberta in forum Newbie / General discussions
    Last Post: 18th Apr 2011, 03:21
  2. Replies: 21
    Last Post: 29th Mar 2011, 14:10
  3. Video aspect ratio conversion
    By cd090580 in forum Video Conversion
    Last Post: 22nd Sep 2008, 06:08
  4. DV 4:3 to 16:9 aspect ratio conversion
    By hysteriah in forum Video Conversion
    Last Post: 9th Dec 2007, 02:40
  5. VIDEO_TS (852x480) -> MPEG conversion: Aspect Ratio?
    By jswayze in forum ffmpegX general discussion
    Last Post: 10th Jun 2007, 09:12
