Hi all my versions are coming up with missing dlls i grabbed 2.5 but am getting the following trying to install it moduleC:\program files\badgerit\svcd2dvd v2.5\code-lock.ocx failed to register. hresult-2147024770. contact your support personnel.
i have removed both 2.1 and 1.5 and they will not install now either
any ideas?
many thanks
Results 1 to 9 of 9
What happens if you type the following in a command prompt:
Code:regsvr32 "C:\program files\badgerit\svcd2dvd v2.5\code-lock.ocx"
does code-lock.ocx exist in C:\program files\badgerit\svcd2dvd v2.5 ?
when i try to run the program i get this :
Version: SVCD2DVD 2.5
Build: 2.5.3000.0
Type: System.IO.FileNotFoundException
Source: System.Windows.Forms
Message: The specified module could not be found. (Exception from HRESULT: 0x8007007E)
InnerException:
StackTrace: at System.Windows.Forms.UnsafeNativeMethods.CoCreateI nstance(Guid& clsid, Object punkOuter, Int32 context, Guid& iid)
at System.Windows.Forms.AxHost.CreateWithoutLicense(G uid clsid)
at System.Windows.Forms.AxHost.CreateWithLicense(Stri ng license, Guid clsid)
at System.Windows.Forms.AxHost.CreateInstanceCore(Gui d clsid)
at System.Windows.Forms.AxHost.CreateInstance()
at System.Windows.Forms.AxHost.GetOcxCreate()
at System.Windows.Forms.AxHost.TransitionUpTo(Int32 state)
at System.Windows.Forms.AxHost.CreateHandle()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.AxHost.EndInit()
at x3284ccece41ee22b.x2f5590cb48bb0c53.x85601834555fb 7d5()
at x3284ccece41ee22b.x2f5590cb48bb0c53..ctor()
at x3284ccece41ee22b.x2f5590cb48bb0c53.xc447809891322 395(String[] xce8d8c7e3c2c2426) -
Just a wild guess, do you have the .NET Framework installed? (Probably version 2.0). If it is, it should be listed in Add/Remove Programs. If it isn't, you need to get it from Microsoft. In theory, during installation of the main program, it should detect if the .NET Framework is present or not and download it if needed.
So regsvr32 "C:\program files\badgerit\svcd2dvd v2.5\code-lock.ocx" gives "specified module could not be found" even though "C:\program files\badgerit\svcd2dvd v2.5\code-lock.ocx" exists?
If this is the case then chances are that you haven't got the VB runtime installed...
Can you search your PC for a file called: MSVBVM60.DLL
If you don't have it then you are missing the visual basic runtime… you can get it from here:
http://www.microsoft.com/downloads/details.aspx?familyid=7B9BA261-7A9C-43E7-9117-F6730...displaylang=en
install that then reinstall S2D.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
that nailed it, many thanks the visual basic runtime did the trick, no idea how the proggy worked fine before then gave up. in any case thank you all very much, it is appreciated
How to lock video files ?
By altaf in forum Newbie / General discussionsReplies: 4Last Post: 30th Nov 2011, 15:30 -
testing thecoalman's suggestion of [code=php] test [/code] ... FAILED!
By vhelp in forum TestReplies: 1Last Post: 10th Jun 2009, 01:15 -
PHP code used to generate code for Avysinth join mov and avi files
By lindylex in forum User guidesReplies: 0Last Post: 19th Sep 2008, 03:37 -
Is SVCD2DVD the program for my HD files?
By rimam in forum SVCD2DVD & VOB2MPGReplies: 19Last Post: 20th Mar 2008, 14:12 -
Code-lock Install Issues v2.5
By PhysicsMatt in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 2nd Jan 2008, 12:32
