Hi guys. I've got a Lite on DVD burner model shw-16p6s.
It has worked great since I bought it (september, last year) but about a few months ago I started having problems with it...
I've had A LOT of burning errors, when I'm burning DVD's (havent burned many cd's lately but as far as I remember I've never had a problem with that)...
I've tried many programs (ususally I use nero) and it still doesn't work most of the time... I tried about 20 times to burn a dvd a few days ago... nothing... it doesn't even write anything to the disc. It comes out empty (though the software says it's burning)... sometimes it does burn but stops with an error...
I've updated my firmware and nothing...
A curious thing is that I've got a DVD-RW that I use to burn my divx movies and it burns perfectly everytime... but when I try with dvd-r's I can't burn a thing (I've tried a few brands... not that many though, cause I had a "tower" and well... that's why I used... but those discs burned fine at first).
I don't know what to do... should I buy a new one?...
Thanks in advance
BTW, here's a log from Nero... if anyone can understand a thing from it
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0002), size=45056 bytes, created 21/11/2005 01:48:20 a.m.
ahead WinASPI: File 'C:\Archivos de programa\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 02/11/2004 12:54:32 p.m.
NT-SPTI used
Nero Version: 6.6.1.15
Internal Version: 6, 6, 1, 15
Recorder: <LITE-ON DVDRW SHW-160P6S>Version: PS0C - HA 1 TA 0 - 6.6.1.15
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <LITE-ON DVDRW SHW-160P6S>Version: PS0C - HA 1 TA 0 - 6.6.1.15
=== Scsi-Device-Map ===
DiskPeripheral : WDC WD800BB-00JHC0 atapi Port 0 ID 0 DMA: On
DiskPeripheral : WDC WD200EB-34BHF0 atapi Port 0 ID 1 DMA: On
CdRomPeripheral : LITE-ON DVDRW SHW-160P6S atapi Port 1 ID 0 DMA: On
CdRomPeripheral : HL-DT-ST CD-RW GCE-8527B atapi Port 1 ID 1 DMA: On
=== CDRom-Device-Map ===
LITE-ON DVDRW SHW-160P6S E: CDRom0
HL-DT-ST CD-RW GCE-8527B J: CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 74448896 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 510MB (522736kB)
Free physical memory: 309MB (316848kB)
Memory in use : 39 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
30.7.2007
ISO compilation
03:41:03 a.m. #1 Text 0 File SCSIPTICommands.cpp, Line 403
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
03:41:03 a.m. #2 Text 0 File Isodoc.cpp, Line 6494
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 2 (Max. of 31 chars)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
03:41:03 a.m. #3 ISO9660GEN -11 File geniso.cpp, Line 3312
First writeable address = 0 (0x00000000)
03:41:03 a.m. #4 Text 0 File Burncd.cpp, Line 3316
Turn on Disc-At-Once, using DVD media
03:41:04 a.m. #5 Text 0 File DlgWaitCD.cpp, Line 281
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 2148639 (477:28.39, 4196MB)
03:41:04 a.m. #6 Text 0 File DlgWaitCD.cpp, Line 293
Write in overburning mode: NO (enabled: CD)
03:41:04 a.m. #7 Text 0 File DlgWaitCD.cpp, Line 2616
Recorder: LITE-ON DVDRW SHW-160P6S, Media type: DVD-R
Disc Manufacturer: RITEKF - 1
Disc Application Code: 64, Disc Physical Code: 193
03:41:04 a.m. #8 Text 0 File DlgWaitCD.cpp, Line 459
>>> Protocol of DlgWaitCD activities: <<<
03:41:04 a.m. #9 Text 0 File ThreadedTransferInterface.cpp, Line 814
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 2148640 (2148640) = #2148640/477:28.40
relocatable, disc pos for caching/writing not required/ required
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2148640 blocks [LITE-ON DVDRW SHW-160P6S]
03:41:04 a.m. #10 Text 0 File ThreadedTransferInterface.cpp, Line 1013
Prepare recorder [LITE-ON DVDRW SHW-160P6S] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4400414720, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep_______ ___
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
2148640 | lead-out | 1 | 0x41 | 0x00
03:41:04 a.m. #11 Text 0 File SCSIPTICommands.cpp, Line 208
SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
03:41:04 a.m. #12 Phase 24 File dlgbrnst.cpp, Line 1685
Caching of files started
03:41:04 a.m. #13 Text 0 File Burncd.cpp, Line 4158
Cache writing successful.
03:41:04 a.m. #14 Phase 25 File dlgbrnst.cpp, Line 1685
Caching of files completed
03:41:04 a.m. #15 Phase 36 File dlgbrnst.cpp, Line 1685
Burn process started at 16x (22.160 KB/s)
03:41:04 a.m. #16 Text 0 File ThreadedTransferInterface.cpp, Line 2717
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
03:41:04 a.m. #17 Text 0 File DVDR.cpp, Line 2846
Recording mode: Sequential Recording Mode
03:41:04 a.m. #18 Text 0 File DVDR.cpp, Line 3002
Start write address at LBA 0
DVD high compatibility mode: Yes
03:41:04 a.m. #19 Text 0 File Cdrdrv.cpp, Line 8737
---- DVD Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 2.1 (33)
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26127F h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Start sector number of the current Border-Out: 0 h
Start sector number of the next Border-In: 0 h
Media Specific [16..63]:
00 60 00 10 20 30 40 50 - 00 00 00 21 00 00 00 00 .`...0@P...!....
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
03:42:14 a.m. #20 Text 0 File Cdrdrv.cpp, Line 1224
03:42:14.296 - E: LITE-ON DVDRW SHW-160P6S : Queue again later
03:44:22 a.m. #21 SPTI -1135 File SCSIPassThrough.cpp, Line 178
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1135)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 00 00 07 8B 00 00 00 20 00 00 00
Sense Area: 0x70 00 03 00 00 00 00 0A 00 00 00 00 0C
Buffer x00000000: Len x10000
0xD0 E7 9E 04 51 05 92 7C 78 07 9E 02 6D 05 92 7C
0x01 00 00 00 78 F6 9E 02 88 5D 9E 02 38 00 00 00
0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
03:44:22 a.m. #22 CDR -1135 File Writer.cpp, Line 281
Write error
03:44:22 a.m. #23 Text 0 File DVDR.cpp, Line 3246
EndDAO: Last written address was 494335
03:44:24 a.m. #24 Phase 38 File dlgbrnst.cpp, Line 1685
Burn process failed at 16x (22.160 KB/s)
03:44:24 a.m. #25 Text 0 File SCSIPTICommands.cpp, Line 253
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
03:44:26 a.m. #26 Text 0 File Cdrdrv.cpp, Line 9945
DriveLocker: UnLockVolume completed
03:44:26 a.m. #27 Text 0 File SCSIPTICommands.cpp, Line 403
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
File 'Drivers\CDRALW2K.SYS': Ver=8.0.0.212 , size=2560 bytes, created 22/04/2007 08:15:25 p.m.
File 'Drivers\ASPI32.SYS': Ver=4.71 (0002) built by: WinDDK, size=16512 bytes, created 21/11/2005 01:48:20 a.m.
File 'Drivers\PXHELP20.SYS': Ver=3.00.43J, size=36624 bytes, created 22/04/2007 08:15:25 p.m. (Prassi/Veritas driver for win 2K)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Thread: dying dvd burner??? help!!!
Sense Key: 0x03 (KEY_MEDIUM_ERROR) Ritek not reliable IMO...
Could be media prob.. try diff. media,and slow down burn to 12x or 8x......see what happens...."I typed the word Google into Google. Guess what came up? Everything."
"What we've got here is failure to communicate"
Try ImgBurn instead of Nero and see if it helps.
And it's always a good idea to try different DVD media to see if it may be the problem as it's the cheapest thing to change.
DVD and CD burning are a separate operation and one may work and the other fail.
And if all that fails, try cleaning the laser lens before you shop for a new burner.
Buy a new burner.
I've used imgburn and it fails aswell...Originally Posted by redwudz
I will check cleaning the lense and changing media
Your LiteOn wasn't a good burner when you took it out of the box. There is no point in trying to diagnose and "fix" it. You can buy a Pioneer 112 for less than $40 if you shop around. Fiddling with your LiteOn isn't worth the hassle and it isn't going anywhere.
Mobo dying?
By Poppa_Meth in forum ComputerReplies: 10Last Post: 26th Apr 2011, 05:50 -
Is my DVD player dying?
By impmon2 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 5th Nov 2009, 00:20 -
How do you know when your DVD writer is dying?
By dqtus in forum DVD & Blu-ray WritersReplies: 12Last Post: 7th Oct 2008, 11:54 -
Is My Drive Dying?
By Gildor57 in forum DVD & Blu-ray WritersReplies: 6Last Post: 20th Aug 2007, 01:03 -
Why do my DVD players keep dying?
By BirdDaddie in forum DVD & Blu-ray PlayersReplies: 32Last Post: 31st May 2007, 04:29
