i often noticed that certain issues affect a/v sync. Hard drive defragging is a plus! Opened too many files? Have enough RAM? I believe prevention is the key to avoiding sync problems.
That being said, I am having a problem with 2 videos i am trying to join together. They both play fine by themselves, but when i go to merge them, the finished product becomes out of sync. I've tried the DivX Pocket Encoder's sync fixing function, to no avail. There's still sync issues there in the final joined product. I used Avi Tricks to join the files together. Even playing the files separate in Avi Tricks showed a sync problem, but playing them with another video viewer, they played fine. My HDD is defragged. I have only 256mb of ram, which i am going to increase soon, but it doesn't seem to be a problem since i opened two files. One was avi tricks, the other was the video i am trying to fix.
any ideas?
Thread: sync issues..what to do!
I have used AVI Demux and Virtualdub to do this successfully a number of times.
One thing to look out for - sometimes the audio in the first file may not run the same length as the video. If this is the case, when you join the two files, the audio on the second file will start early.
Weird Sync Issues
By koberulz in forum Newbie / General discussionsReplies: 10Last Post: 26th Mar 2012, 11:56 -
Subtitle Sync Issues
By TheAlmighty in forum SubtitleReplies: 6Last Post: 2nd May 2010, 00:13 -
Sync Issues
By jah711 in forum Blu-ray RippingReplies: 0Last Post: 27th Oct 2009, 00:41 -
tsMuxeRGUI and sync issues?
By BritishDragon in forum Authoring (Blu-ray)Replies: 7Last Post: 30th May 2009, 11:55 -
Audio Sync Issues
By Pinata in forum DVD RippingReplies: 2Last Post: 28th Jan 2008, 08:38
Statistics
Newest guides
Latest tool updates
New media comments
