VideoHelp.com Forum
    I have pretty much had it up to the eyes with PowerProducer. It runs like a dead dog dying on a machine that never has any trouble copying a DVD in less than ten minutes. I am trying to convert HDV footage down to DVD-Video for friends and relatives, but finding a program with which to do it is next to impossible. I have been contemplating buying a Mac to edit video with, but do not have the budget for it as yet. How can I get my HD footage onto DVD+R?
    "It's getting to the point now when I'm with you, I no longer want to have something stuck in my eye..."
    the actual editing and encoding part of powerproducer is pretty good in the speed department. the slowdown is during the de-muxing operation. the problem is that any program that edits/encodes HD is going to have to do the same thing and it will take just as long. the only way out i can think of is if you use a transcoder that doesn't do any editing(or allow many options usually). maybe try convertxtodvd? another thing that can help increase the speed is 2 separate physical hard drives. one to read from and one to write to during the encoding process.
  1. Audio Codec Not Working in PowerProducer
    By travbickle in forum Software Playing
    Last Post: 5th Dec 2011, 13:28
  2. Replies: 1
    Last Post: 15th Feb 2011, 08:34
  3. PowerProducer - edit dvd menu template
    By kj1983 in forum Authoring (DVD)
    Last Post: 3rd Oct 2008, 18:37
  4. Alternatives to Anydvd hd?
    By yoda313 in forum Blu-ray Ripping
    Last Post: 15th Aug 2008, 11:22
  5. Using Cyberlink PowerProducer... no video during authoring
    By 27am_dot_com in forum Authoring (DVD)
    Last Post: 9th May 2007, 19:55
