I have tried everything! I tried looking for solutions and I finnaly tried formatting my HDD and re installing Vista Buisness 32Bit edition
I'm running:
1x GeForce 8800GTS 320MB
1x Dual Core AMD 63Bit 4800+ Processor
2x 1GB DDRII Ram Total 2
Xvid4PSP will not fully convert a video for me it just shuts down in the middle even after the format
Formatting did fix a couple things like I can use 3Gp properly however it not recently just shutdown on me
I can now use Netflix instant movie viewer when I could not before
BUT WHAT IS GOING ON HERE?!
Now either Vista just got me a update that sucks and screws with things or peopple are lying cause a couple said I have Vista and can run Xvid fine! What am I suppose to do I can't use Xvid or 3GP and I doubt PSPvideo9 wont shutdown within time![]()
People (users) , either know it works , or a having a speculated guess from what they have been able to locate in relation to vista .
There's also many issues between intel and amd dual cores which popup .
Have you tried :
A: Run program required ... do not do anything yet .
B: Ctrl + alt + dell (task manager)
C: Locate program in running tasks
D: Right click on it , and you should get an option box
It allows you to set the process's priority , and wether it is to be run using dual processors or one only .
I have trouble with dvdshrink if dual processors are used ... never a problem if core id is 0 (first up)
It might just help with xvid4psp ... but then , when it comes to such tools , if there is anything not quite right with the clip being converted , these can cause such problems .
There is also the issue between the different versions of vista , which needs to be checked out as well .
I'll note , that my issue is under xp pro with dual core intel , but vista should still support the task manager theory ... just the vista system I have tested is another users , and its not here right now .
Vista should support programs running in "compatability mode" as well : http://windowshelp.microsoft.com/Win...f5f101033.mspx
Then there's uac deal : http://lifehacker.com/software/vista...pts-230866.php
You are now known as a "administrator" for the current pc ... well , since xp came out , and its up to you to keep a close eye on those updates from ms ... some are well known right screwups , which cause havoc .
And watch that retarded program ...xvid4psp ... uninstalling it can mess with other products as it deregisters many codecs and filters ... its bad news , dont touch it .
MM Xvid is retarted? I will look into that :P but I think setting it to only 1 worked I guess two cores are not ment for converters really.
External HDD - standing or lying down
By uno in forum ComputerReplies: 4Last Post: 29th Jun 2011, 15:06 -
How old are you - part 2 (no lying now)
By yoda313 in forum PollsReplies: 95Last Post: 4th Oct 2009, 09:00 -
Virtualdubmod is lying
By zinc in forum Video ConversionReplies: 12Last Post: 12th Jun 2008, 10:54 -
How old are you (no lying now)
By Craig Tucker in forum PollsReplies: 284Last Post: 12th Jun 2008, 10:01 -
Why is compressor lying to me??
By whiff79 in forum MacReplies: 2Last Post: 4th Jun 2007, 14:38
Statistics
Newest guides
Latest tool updates
New media comments
