I recently bought a Sony BRC 300 camera. I also bought the BRBK-301 card that goes in this camera (it's similar to putting a graphics card into your computer) so that instead of it's standard S-Video and composit, the BRBK-301 allows it to do "analog RGB output". The terminal that they have on the card is a 9 pin (DE9) d-subminiture connection (see this for reference). I need to go to a regular 15 pin vga signal to display on a computer monitor. I was told by tech support before I bought this that it was possible with only the adapter. I bought a simple 9-pin to 15 pin (VGA) adapter and it doesn't appear to be translating the signal correctly. Has anyone dealt with these connections/signals before and have any wisdom to share. Thank you.
-Matt
I don't know that camera or the adaptor card, but I suspect it is putting out RGB with standard video timing (29.97 fps interlaced). Most computer monitors will not sync that low.
Cannot find DV output pin
By RalphW in forum CapturingReplies: 10Last Post: 2nd Mar 2012, 13:25 -
Convert S-VHS output to VGA Hardware Question
By videomont in forum Video ConversionReplies: 5Last Post: 10th Jan 2011, 17:07 -
vga output has stopped working and I don't know why
By xtube in forum Newbie / General discussionsReplies: 0Last Post: 12th Aug 2010, 02:33 -
cant output 1920x1080 through vga
By sitlet in forum ComputerReplies: 13Last Post: 27th Jan 2009, 17:34 -
FML VGA to FML 2 3 pin XLR, L R Rca Audio, Composite BNC, S-video Breakout
By silverlage in forum CapturingReplies: 1Last Post: 12th Dec 2008, 11:07
Statistics
Newest guides
Latest tool updates
New media comments
