I own a Divx standalone player with USB support and it works fine on memory sticks
However today tried out with new external USB HDD formated as FAT32 and its not recognised
Is there a glaringly obvious solution to this or is this just not possible on standalone players?
Any help/pointers appriciated
P
http://www.nexuslive.com
The UK's First Live Online Music Show
And what brand / model would it be you are refering to ?
Its a Maxtor 3200 500GB USB drive on a Tevion (sorry not at home so can't see model number will check this evening) from UK Aldi store
Just wondered what the standard would be for formating drive like this to function as a media libary for player
Is it the caddys firmware itself thats the problem?
I had an old 20GB maxtor drive on a usb to ide connection working on this machine earlier in year
But I'm finding it difficult to discover exactly what the standard/filesize limit etc is for these things
Perhaps there isn't one...?
Any help appriciated
This topic has almost 200,000 views & has ideas:
http://forum.videohelp.com/topic301465.html
cheers for the tip
but no solution as yet
most interesting possibitys are making drive be read as removable storage however no tutural as yet as to how to do this
Last night got the seagate 3200 500GB drive to work
Used FAT32Format one partion and primary and plugged drive in first then into USB, switched on machine at first i got the wee hand signal that usually means no sisk but after a wait of about a minute it came up.
Files played reasonablely smoothly (much better than usb pen)
Thanks for pointer to the other thread
Perhaps someone could assemble a FAQ on this stuff somewhere (don't really have the know how myself unfort)
Which hdtv's have a USB port, so you can plug in a flash drive or USB HDD?
By snafubaby in forum DVB / HDTVReplies: 8Last Post: 30th Nov 2010, 16:03 -
Question about using external hard drive with USB DVD player
By jimdagys in forum ComputerReplies: 2Last Post: 29th Jul 2009, 18:49 -
Standalone Divx/Xvid player with remote & usb
By bxr510 in forum Media Center PC / MediaCentersReplies: 5Last Post: 19th Aug 2008, 06:19 -
external USB HDD and standalone player Survey
By nalooti in forum Portable VideoReplies: 0Last Post: 18th Dec 2007, 04:30
