VideoHelp.com Forum
  1. Member LITEONDVD's Avatar
    Is it possible to convert flv to wmv? or mpg to wmv? If so what freeware program? I'm also wondering if i convert an mpg file from VOB2MPG and convert it to wmv (if that's possible) would it work on WMM?
    LITEON man!
  2. Member yoda313's Avatar
    try super. It has flv support and says it can output mpg.
    Though I've never used it that I know of that is the description it has in the tools section.
    You should be able to mpg to wmv with windows movie maker - that is one of the supported files.
  3. Member LITEONDVD's Avatar
    Problem is WMM wont read my mpg file
    LITEON man!
  4. Member LITEONDVD's Avatar
    anybody else?
    LITEON man!
    any info on this file?
  6. Member LITEONDVD's Avatar
    nvm i found a solution. I downloaded super and just did .flv to wmv -(MS mpeg4 v2 i think it was) from the output video codec and set wmv as the output container. Same with the non working mpg file. Just coverted it to the same things above. (just put it as WMV - MS MPEG 4.
    Thanks anyways.
    LITEON man!
  1. [Help] wmv to flv with ffmpeg
    By Nightslk in forum Video Conversion
    Last Post: 4th Aug 2009, 12:52
  2. wmv to flv converting?
    By 2mmy in forum Video Conversion
    Last Post: 1st Aug 2008, 13:59
  3. FLV to WMV trouble
    By seeviper in forum Video Conversion
    Last Post: 6th Apr 2008, 20:06
  4. FLV to WMV help
    By mikeak21 in forum Video Conversion
    Last Post: 28th Oct 2007, 20:45
  5. .wmv to .flv
    By KameronK in forum Capturing
    Last Post: 20th Aug 2007, 10:36
