I just dont know what mistake I am doing ?
I have the xsub and avi/divx file but divxmuxgui wont write subtitles to the video file ?
What mux mode should I chooose ? any help ?
I even tried with srt files. The final output could be played on wmp and classic windows media player with subtitles but without subtitles on vlc. It would not play at all on my divx hardware player. The reason is obvious if you see the output video file details.
These are the file details:
Input file details by avicodec:
File : 696 MB (696 MB), duration: 1:47:55, type: AVI, 1 audio stream(s), quality: 46 %, VirtualDubMod 1.5.10.1 (build 2439/release), ,
Video : 601 MB, 779 Kbps, 23.975 fps, 640*272 (Unknown), XVID = XVID Mpeg-4, Supported
Audio : 95 MB, 123 Kbps, 48000 Hz, 2 channels, 0x55 = Lame MP3, VBR, , Supported
Output file details by avicodec:
File : 693 MB (1.11 MB), duration: 1:47:55, type: AVI, 1 audio stream(s), quality: 71 %, AVI-Mux GUI 1.17.7, Aug 8 2006 20:59:17, ,
Video : 3.90 GB, 5184 Kbps, 23.976 fps, 640*272 (Unknown), XVID = XVID Mpeg-4, Supported
What is wrong going on here![]()
I guess divxmux failed to open the avi file. I encountered this situation sometimes.
If it is really the case, i think you can open the avi file with virtualdub or avidemux and save it as another avi file (direct stream copy). in my case, divxmux tends to work well with the new avi file created above.
VLC looks washed out compared to WMP
By stringcheesy in forum Software PlayingReplies: 3Last Post: 11th Sep 2011, 23:27 -
Is it possible to find the actual stream URL for Air1 to play in WMP/VLC?
By AshleyQuick in forum Video StreamingReplies: 4Last Post: 4th Sep 2011, 22:36 -
WMS Stream in WMP / Vlc
By river3 in forum Video StreamingReplies: 0Last Post: 15th Jun 2010, 03:18 -
Samsung HD video won't play in VLC, but will in Win 7 WMP... why?
By wild_fan in forum Software PlayingReplies: 3Last Post: 18th Dec 2009, 12:33 -
subtitles in VLC won't play
By petliura in forum SubtitleReplies: 1Last Post: 10th Dec 2008, 08:16
Statistics
Newest guides
Latest tool updates
New media comments
