Means should i try an older vesion of MeGui ? I'm currently using 0.3.1.1056.Current versions of megui are broken. Active development on the project has stopped (the gui doesn't match newer recent x264 features)
Results 151 to 168 of 168
If you want to use new x264 features, you can learn the commandline (x264 has been revamped to use preset system )http://mewiki.project357.com/wiki/X264_Settings
or switch to a gui that has active development like staxrip, hdconverttox, xvid4psp, or ripbot264
It's a shame, because megui was the most comprehensive solution, but older builds should still work fine.
I don't get what u mean by try ffmpegsource2.
http://code.google.com/p/ffmpegsource/downloads/list
I've downloaded ffms2-r234-2.7z from there. Now what should i do?
Unzip the contents into avisynth/plugins folder , including the .dlls and .avsi
There is a readme for more information and instructions
Skip the avs creater and make your own .avs script
e.g.
FFVideoSource("video.m2ts")
If you want audio & video served
FFMpegSource2("video.m2ts", atrack=-1)
create my own means
replace this
DirectShowSource("C:\TEST\video.m2ts", fps=23.976, audio=false, convertfps=true)
with FFVideoSource("video.m2ts")
Well after doing, unzip ffms to avs plugin folder & replacing the directshowsource with ffdvideosource in tha avs script i open the script with MeGui and now it says that FFdvideo source doesn't have the arguement "fps".
LoadPlugin("C:\AviSynth 2.5\plugins\TIVTC.dll")
# Set DAR in encoder to 37 : 20. The following line is for automatic signalling
global MeGUI_darx = 37
global MeGUI_dary = 20
FFVideoSource("C:\TEST\video.m2ts")
AssumeFPS(24000,1001)
#deinterlace
crop( 0, 20, 0, -22)
#resize
#denoise
Now this is how my script is looking.
The script plays fine with mpc but the seeking is not working.
MeGui is not responding if i open that script.
Try opening the .avs in vdub. Don't "play" it, but just drag the slider around
Did you let it finish indexing?
Is everything and all programs, splitters, filters in the 32-bit directory?
%windir%\SysWOW64 and
\Program Files (x86)
It seems like you have configuration or system problems.
I would try another GUI instead of fighting to get this to work
Out of the GUI's I would use ripbot264 for the easiest to use, and it's updated frequently by the author
I actually don't use any of those GUI's anymore. The new preset system makes things alot easier.
Also if you learn more about avisynth, you don't waste time analyzing the file - which these gui's do - it can a lot of time on encoding.
Any links 4 Avisynth tutorials ?
Unfortunately not any good ones because there so much to learn, it's a huge topic. You could write several books on it... It is the most powerful tool out there from editing, filtering, manipulations, deinterlacing etc. etc...
You can start here
http://avisynth.org/mediawiki/Main_Page
If all you are doing is a straight progressive encode, then it's pretty simple. You just need a simple source filter like DirectShowSource() for example (there are others)
But one of the purpose of the GUI's is to make things easier, so you don't have to worry about all the avisynth stuff
Okies, Thanks
You'll need to unpack the 7-Zip archive (7z). Use 7-Zip. It's open source and free. It should come with an installer once you get it unpacked.
http://www.7-zip.org/Impossible to see the future is. The Dark Side clouds everything...
I've downloaded it & installed it. Now can u tell me y i did it, means vatz its purpose??
ok, I'am really new to this, and lost i have win7 64, trying to do terminator salvation films i backed up the files to my hd using dvdfabhd latest, and have the my TERMINATOR_SALVATION_DC\BDMV\STREAM\00004.m2ts file i followed the steps from the first post, but of course as seeing that was older date, and skimmed thru a few of the later posts/replies i nooticed the you say mgui it broke with the newest version? and as for the first step to put this line in : DirectShowSource("x:\VIDEO PROCESSING\backups\DONE\MainMovie\TERMINATOR_SALVA TION_DC\BDMV\STREAM\00004.m2ts",fps=23.976,audio=false) and play it in a player like vlc or wmp it wont work, so i can even get past that, step, so if there is a new way to do the whole process or not can you explain more in detail cuz i dont follow,....i found another guide of a different forum, but i get errors as the avs says the file/source cant be found, which doesnt make any sense the steps on that site are this: (PLEASE READ THE NOTE IN ALL CAPS TO SEE WHAT I DID, THANKS!
1) Start tsMuxeR and browse to your main movie file (BDMV/STREAM/00000.m2ts). -I DID THIS HAD NO ISSUES
2) Demux the desired audio and subtitle streams (don't worry about the video). - I DONT KNOW WHAT THIS MEANS!!!??
3) Create a script in AVIsynth: DirectShowSource("D:\YOUR_BLURAY_VIDEO/BDMV/STREAM/00000.m2ts") - I DID THIS WHICH I CHANGED THE SOURCE AND POINTED IT TO MY FILE
4) Load the AVIsynth script into MeGUI and use the MeGUI Blu-ray profiles as linked to in the links section -I DID THIS BUT GOT THE ERRORS THAT I MENTIONED BEFORE......
5) Load new h264 (in MKV container) created from MeGUI along with the other audio & subtitle streams you want to keep into tsMuxeR. - NEVER GOT TO THIS STEP!!!
6) Save new m2ts media file or output Blu-ray folders to burn to disc.
AVI to Blue Ray
By bohdank in forum Video ConversionReplies: 2Last Post: 12th Mar 2011, 12:38 -
Help with meGUI- Blu-ray to avi
By badreligionhead in forum Blu-ray RippingReplies: 0Last Post: 9th Aug 2009, 19:13 -
AVI to Blue Ray
By luvflt in forum Newbie / General discussionsReplies: 1Last Post: 18th Jan 2009, 16:40 -
Blue Ray WITH DVD (Disney)
By ron spencer in forum Latest Video NewsReplies: 14Last Post: 17th Jan 2009, 19:55 -
Blue-ray DVD-ROM?
By wulf109 in forum DVD RippingReplies: 3Last Post: 11th Aug 2007, 04:30
