I'm borrowing a friend's Sony Digital-8 (510) to capture all my old 8mm camcorder stuff (20 cassettes) to my HD (avi format). I know, this will take up quite a bit of room but I was told it's best to capture to HD given the problems you can have with burning to DVD. This way I can pic-n-choose footage to burn. Also, I believe they will have less chance of loosing footage with the volatility of DVDs. Is there a good free "burn-directly-to-drive" software that I can get my hands on? And does anyone know if this Sony has direct "digital-conversion-pass-through" capability? I'll be getting it in the next few weeks.
Thanks in advance.
Bob.
Thread: Capture / Burn direct to drive
You need a FireWire card and cable, then just use WinDV for a direct transfer to your hard drive. The camera appears to have passthrough, at least it has AV inputs.
And welcome to our forums.
I've got firewire since I do this all the time with my trv900. I don't have the camcorder yet and I guess what you're saying is it has a firewire connection. I didn't know that. What is your opinion on the HD vs DVD storage especially when it comes to home archiving?
Thanks for the info and....the welcome.
Generally, it's best to keep them on tape, but since they're not DV, next best would be DVD data discs. JMO, though.
If I have the right model camcorder, this should be a manual for it: http://esupport.sony.com/US/perl/mod...?mdl=DCRTRV510
My 'rule of thumb' is to never put anything on a hard drive that you can't afford to lose.
Thanks for the info. I also found it on another site:
www.retrevo.com
By-the-way, I always thought that if my HD went belly-up that I'd still be able to retrieve the data. As opposed to DVD and depending on the extent of the damage, it's usually done. Also, doesn't mini-DV tape have a life cycle of about 15 yrs?
In any case, thanks for your help.
Considering I have perfectly good VHS tapes that are a lot older than 20 years, I wouldn't worry too much. Mainly keep them stored in a cool dry place out of sunlight and they should last long enough.
Depending on how a hard drive dies, it can cost a lot of $$$ to recover the data. DVDs are cheap, but use a good quality, store properly and they should also make it to 20 years.
Internal Capture Card? Possible to Capture direct to PC?
By Ryutso in forum CapturingReplies: 11Last Post: 25th Jul 2010, 15:58 -
can I burn avi's direct to jump drive or computer desktop Toast9
By BattyRoy in forum MacReplies: 4Last Post: 9th Aug 2009, 23:06 -
Can I transfer my direct tv dvr movies to a hard drive?
By Vityaz in forum DVB / HDTVReplies: 11Last Post: 23rd Jun 2009, 16:54 -
Direct from DVR to computer hard drive?
By jdcrowley in forum DVD & Blu-ray RecordersReplies: 2Last Post: 29th Sep 2008, 21:08 -
Hard drive camcorder direct to DVD burner?
By h08 in forum DVD & Blu-ray WritersReplies: 7Last Post: 12th Oct 2007, 17:47
