    Good day lads..
    Needs some help with a .3gp file; which i deleted of my phone ; but which i have recoved with some recovery software.. Now none of the programs (Nokia player ; VLC ; Quiktime) will play it.. Its probably damaged.. Can somebody advise what to use to fix something like this??
    I really need those files...
    Appreciate any help!
    Cheers en bedankt!
    This is the details screen for a working file ;
    SUPER © - Multimedia Analysis Box (by http://mediainfo.sourceforge.net )
    Analyzing the source file Video000.3gp
    General #0
    Count : 177
    Count of stream of this kind : 1
    Kind of stream : General
    StreamKindID : 0
    Count of video streams : 1
    Count of audio streams : 1
    Count of text streams : 0
    Count of chapter streams : 0
    Codecs Video : H.263
    Audio codecs : AMR-NB
    Complete name : C:\Documents and Settings\My Documents\Downloads\Trend.Micro.InterScan.VirusWal l.v6.02.7165-CROSSFiRE\Video000.3gp
    Folder name : C:\Documents and Settings\My Documents\Downloads\Trend.Micro.InterScan.VirusWal l.v6.02.7165-CROSSFiRE
    File name : Video000
    File extension : 3gp
    Format : 3gp5
    Format : 3GPP
    Format/Family : MPEG-4
    Format/Url : http://www.apple.com/quicktime/download/standalone.html
    Format/Extensions : 3gpp 3gp k3g
    Codec : 3gp5
    Codec : 3GPP
    Codec/Family : MPEG-4
    Codec/Url : http://www.apple.com/quicktime/download/standalone.html
    Codec/Extensions : 3gpp 3gp k3g
    File size : 274736
    File size : 268 KiB
    File size : 268 KiB
    File size : 268 KiB
    File size : 268 KiB
    File size : 268.3 KiB
    PlayTime : 19920
    PlayTime : 19s 920ms
    PlayTime : 00:00:19.920
    Bit rate : 110335
    Bit rate : 110 Kbps
    StreamSize : 4408
    StreamSize : 4.30 KiB
    StreamSize : 4 KiB
    StreamSize : 4.3 KiB
    StreamSize : 4.305 KiB
    Encoded date : UTC 2007-03-02 13:15:48
    Tagged date : UTC 2007-03-02 13:15:48
    Video #0
    Count : 74
    Kind of stream : Video
    StreamKindID : 0
    Codec : s263
    Codec : H.263
    Codec/Info : H.263 (3GPP)
    PlayTime : 19861
    PlayTime : 19s 861ms
    PlayTime : 00:00:19.861
    Bit rate : 96049
    Bit rate : 96 Kbps
    Width : 176
    Width : 176 pixels
    Height : 144
    Height : 144 pixels
    Aspect ratio : 1.222
    Frame rate : 15.306
    Frame rate : 15.306 fps
    Minimum frame rate : 5.585
    Minimum frame rate : 5.585 fps
    Maximum frame rate : 17.559
    Maximum frame rate : 17.559 fps
    FrameCount : 304
    StreamSize : 238456
    StreamSize : 233 KiB
    StreamSize : 232.9 KiB
    Audio #0
    Count : 60
    Kind of stream : Audio
    StreamKindID : 0
    Codec : samr
    Codec : AMR-NB
    Codec/Info : AMR narrow band (3GPP)
    PlayTime : 19920
    Bit rate : 12800
    Bit rate : 13 Kbps
    Channel(s) : 2
    Channel(s) : 2 channels
    Sampling rate : 15750
    Sampling rate : 16 KHz
    SamplingCount : 313740
    Resolution : 16
    Resolution : 16 bits
    StreamSize : 31872
    StreamSize : 31.1 KiB
    StreamSize : 31 KiB
    StreamSize : 31 KiB
    StreamSize : 31.13 KiB
    __________________________________________________ _________________________________
    and this for the DAMAGED FILE which i want to repair;
    Analyzing the source file Video008.3gp
    General #0
    Count : 177
    StreamKindID : 0
    Count of video streams : 0
    Count of audio streams : 0
    Complete name : C:\Documents and Settings\My Documents\vid\Video008.3gp
    Folder name : C:\Documents and Settings\My Documents\vid
    File name : Video008
    Format : BDAV
    Codec : BDAV
    File size : 197350
    File size : 193 KiB
    File size : 193 KiB
    File size : 193 KiB
    File size : 193 KiB
    File size : 192.7 KiB
    I dont know how to fix this... Anybody have another idea please...??
    Thanks in advance!!
    I don't think you can,
    maybe if you used a HEX EDITOR program and compared the first part of tha damaged file with the first part of a good file, you edit the damaged file to correct the header info
    the header info typicaly gives the file size, the bitrate info, the file name , and file type , and where the file itself actually starts
    in the past I have edited bitmap files and jpegs, and other file types (but never any video files) to put custom wallpaper on a phone that didn't have the option of importing any ( lg 3200 )
    create an edit a special bitmap file to overwrite the existing file in the phone.
    but i haven't tried repairing a recovered damaged 3gp video file
    Thanks! I have never worked with a HEX program.. but will give it a go... I am desperate enough...
    Will let you know if it work.. 8)
    Did you ever managed to work things out?
    Is het gelukt?
    Have kind of the same problem..
    up for this topic, I can't find a decent program that can revive this kind of format.
    hope one of the experts reply.
    up for this thread! any expert out there in recovering these kinds of issues? thanks!
    EDIT: Replied to wrong thread. Doh!
