Is there anyway to merge m2ts files? While I use Tsremux regularly & it works great there is unfortunately no way to merge the files together.
Thanks In Advance,
Wf
Thread: Merging M2ts
You could try using DGINDEX and demux the files. It will allow you to add multiple input files. Then select "File -> Save Project and Demux Video".
Impossible to see the future is. The Dark Side clouds everything...
Merging/Converting Multiple M2TS files to MKV With Multiple Audio Tracks
By Nicholas S. Folsom in forum Video ConversionReplies: 1Last Post: 13th May 2011, 18:34 -
mux m2ts to m2ts with AC3 audio without reencoding the video
By BirdDaddie in forum Video ConversionReplies: 3Last Post: 22nd Aug 2010, 21:19 -
Help with multiple .m2ts files to one .m2ts
By neworldman in forum Blu-ray RippingReplies: 7Last Post: 17th Mar 2010, 19:39 -
Audio drifting when merging Sony .m2ts files in tsMuxeR
By jaholmes in forum Authoring (Blu-ray)Replies: 2Last Post: 28th Sep 2009, 12:02 -
Edit M2TS and saving it as M2TS
By Andreas Furumo in forum Video ConversionReplies: 3Last Post: 28th Aug 2009, 14:07
Statistics
Newest guides
Latest tool updates
New media comments
