I've got the following video (MediaInfo output):
How can it be 720x480 AND 16:9? 720x480 is 4:3 so why is the aspect ratio being reported as 16:9? It IS a letterbox video pulled from an episodic television series DVD so I believe the 16:9 part but how can it be 720x480?Code:General #0 Complete name : J:\Temp\test.mpg Format : MPEG-2 Program Format/Family : MPEG-2 File size : 167 MiB PlayTime : 4mn 32s Bit rate : 5149 Kbps Writing library : Apr 29 2003 Video #0 Codec : MPEG-2 Video Codec profile : Main@Main Codec settings/Matri : Custom PlayTime : 4mn 32s Bit rate : 9800 Kbps Bit rate mode : CBR Width : 720 pixels Height : 480 pixels Aspect ratio : 16/9 Frame rate : 29.970 fps Standard : Composite Chroma : 4:2:0 Interlacement : Top Field First Bits/(Pixel*Frame) : 0.946 Writing library : Apr 29 2003 Audio #0 Codec : AC3 Codec profile : Dolby Digital PlayTime : 4mn 32s Bit rate : 192 Kbps Bit rate mode : CBR Channel(s) : 2 channels Sampling rate : 48 KHz Video0 delay : 31ms ChannelPositions : L R
I'm trying to convert it to 4:3 720x480 with ffmpeg so I can view the video on my ReplayTV DVR but everything I try ends up with the aspect ratio all screwed up. I've tried various attempts at padding and/or cropping but still haven't found the correct combination to result in a properly formatted 4:3 video.
Thread: 16:9 to 4:3 confusion
Display aspect ratio can be independent of frame size. DVD/MPEG has a flag that specifies whether the 720x480 frame should be displayed as 4:3 or 16:9.
There are two ways you can convert 16:9 to 4:3:
1) Cut a total of 180 pixels off the right and left (eg 90 off the left, 90 off the right), stretch what's left to 720x480 and encode as 4:3.
2) Resize the 720x480 frame to 720x360, add a total of 120 lines of black to the top and bottom (eg, 60 top, 60 bottom), then encode as 4:3.
DVD uses non-square pixels. The pixel aspect ratio helps display the image correctly based o the AR flag. If you changed the AR flag (ReStream can do this for you, if you want to play around with it) then you will find the image appears to be tall and thin.
To truely convert it to 4:3 you will have to resize the video, then re-encode it. If you are trying to convert it to full screen 4:3 then you will also have to crop, then resize the video. Given the source is interlaced, you risk doing quite some damage to it.
What do you really want to do with it ?
No, 720x480 is 3:2. It gets resized by the player based on the DAR, in this case 16:9.Originally Posted by zabolots
Quick overview.
720x480 is displayed as 640x480 (4:3) or ~854x480 (16x9) on square pixel displays or is upscaled from there to the TV resolution.
For analog TV sets the TV will horizontally squeeze it if the flag indicates 4:3. If the video is flagged 16:9 or "wide", the set top box, DVD player or TV will default rescale the image vertically for letterbox display.
If the set top box or DVD player are set to wide display the video is passed as is to the wide TV which then stretches the picture horizontally to 16:9.
like THEY say, ALL mpeg files for DVD & TV are 720*480 resolution, std is display as 4:3
widescreen is displayed as 16:9
to keep circles round and people in perspective ( correctly proportioned )
you have to crop the video frame if you want the picture to fill the 4:3 TV screen
too top it off, movies are not 4:3 or 16:9 they are 2:21 2:35 18:1 or something else
it is fitted/encoded to 16:9 DAR or 4:3 DAR with a 720*480 real data/pixel resolution when the DVD is made
Bluray confusion
By Border Reiver in forum Newbie / General discussionsReplies: 6Last Post: 5th Nov 2009, 16:41 -
AVIVO Confusion
By jameson_uk in forum Software PlayingReplies: 2Last Post: 11th Sep 2008, 17:44 -
Wi-Fi noobie confusion.
By Xylob the Destroyer in forum ComputerReplies: 18Last Post: 23rd May 2008, 11:59 -
Interlace confusion
By Bagshot in forum CapturingReplies: 7Last Post: 16th Feb 2008, 08:46 -
Video CD confusion
By bryankendall in forum Newbie / General discussionsReplies: 9Last Post: 6th Jan 2008, 17:17
