VideoHelp.com Forum
    I just got rid of some equipment, changed a few other things around, and have run into a problem.
    I used to have my Cyberhome DVD player hooked up to a TV with regular RCA cables. I now have it hookedup to my big 32" TV with the YPrPB component video cables my old and now-dead DVD player had. However, I'm getting a very screwed up signal.
    The TV shows a hash of the "Cyberhome" screensaver logo, tinged a redish/greenish colour.
    I've tried swapping out plugs, thought I had them in the wrong plugs (I have a loss of a lot of my colour vision), made sure they were plugged in tight too. No help.
    Any ideas what I might be doing wrong folks? I'd appreciate any help, thanks.
    My gear:
    - JVC HR-S9911U SVHS VCR
    - Datavideo TBC-1000
    - JVC DR-M10 DVD writer
    - Sony Steadyshot DCR-TRV340 NTSC Digital8 Camcorder
  2. Member edDV's Avatar
    May be a defective or misplugged cable but are you sure you've set the Cyberhome player to component out in the settings?
    The typical settings are
    S-Video/Composite or YPbPr
    480i (interlace) or 480p (progressive).
    For A typical NTSC TV with component inputs, set to YPbPr and 480i.
    If the TV is a progressive LCD or HD-Ready, set to YPbPr and 480p.
    Thanks, I'll check out those settings and see if my TV is progressive-capable (it's a 32" CRT), and hopefully that will fix my problem. Appreciate the help!
    My gear:
  4. Member edDV's Avatar
    Most likely not progressive and you might damage the TV if not.
    Check the manual. If they don't call it a 480p EDTV or HD Ready it isn't progressive capable.
  1. DVD "no signal" with component connection
    By medic in forum Authoring (DVD)
    Last Post: 31st Mar 2012, 18:23
  2. Intel GMA HD/Core i3 - VGA has TV-out/S-video-out/component-video-out?
    By Morality124 in forum Media Center PC / MediaCenters
    Last Post: 9th Jan 2011, 00:44
  3. RCA composite video on Wii but component video and VGA inputs on tv
    By shashgo in forum Newbie / General discussions
    Last Post: 22nd Aug 2010, 21:48
  4. Card for capturing HD Component Signal
    By peez in forum Capturing
    Last Post: 10th Nov 2009, 09:42
  5. Compatibility of composite video output VCR with component video input TV
    By boshu22 in forum Newbie / General discussions
    Last Post: 7th Sep 2009, 22:46
