VideoHelp.com Forum
Results 1 to 10 of 10
    During the installation of mpeg2enc, mencoder, and mplayer I get this error message
    The installation was not successfull.
    ##sh: -c: line 1: unexpected EOF while looking for matching `''
    sh: -c: line 2: syntax error: unexpected end of file
    Any ideas?
    dmf
  2. Sounds like a corrupted, invalid, or damaged file. The message is saying that the software came to the End OF a File before it expected to, and that should NEVER happen.
  3. Explorer Case's Avatar
    However, in this case it may be totally different because of the first error line.
    The installer is looking for a second quote symbol (in a path most likely), but never finds it.
    This would happen if you have a quote symbol in a disk name, folder name, or file name, like Pete's folder.
    Make sure you remove all spaces and special characters from the names of any disk, folder or file that ffmpegX could use. Because those characters will get a special meaning for the installer in the Unix command line language that is used in the background.
    Hey guys!
    I have exactly this problem!
    ##sh: -c: line 0: unexpected EOF while looking for matching `''
    sh: -c: line 1: syntax error: unexpected end of file
    However, I checked, and I have no accents in folders! ><
  5. Explorer Case's Avatar
    Could it be that your account password has such a character?
    !!!!! Thank you for solving it! xD I had it in my password! ^^
    I could have never thought of that on my own!
    Next problem:
    Encoding started on Mon Jan  9 21:50:09 CET 2012
    MEncoder dev-CVS-060307-04:23-4.0.1 (C) 2000-2006 MPlayer Team
    Mac OSX static build for ffmpegX
    FIXME:Hardenabling SSE and SSE2 without detection
    CPU: Intel Pentium III Xeon Cascades (Family: 6, Stepping: 7)
    CPUflags: Type: 6 MMX: 1 MMX2: 1 3DNow: 0 3DNow2: 0 SSE: 1 SSE2: 1
    Compiled for x86 CPU with extensions: MMX MMX2 SSE SSE2
    success: format: 0  data: 0x0 - 0x5909130
    ISO: File Type Major Brand: ISO/IEC 14496-1 (MPEG-4 system) v2
    Quicktime/MOV file format detected.
    MOV: selected audio stream (0) does not exists
    VIDEO:  [avc1]  960x512  24bpp  7.992 fps    0.0 kbps ( 0.0 kbyte/s)
    [V] filefmt:7  fourcc:0x31637661  size:960x512  fps: 7.99  ftime:=0.1251
    Opening video filter: [expand osd=1]
    Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1
    Opening video filter: [scale w=960 h=512]
    Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
    Selected video codec: [ffh264] vfm: ffmpeg (FFmpeg H.264)
    Forcing output fourcc to 58564944 [DIVX]
    VDec: vo config request - 960 x 512 (preferred colorspace: Planar YV12)
    VDec: using Planar YV12 as output csp (no 0)
    Movie-Aspect is 1.85:1 - prescaling to correct movie aspect.
    SwScaler: using unscaled Planar YV12 -> Planar YV12 special converter
    videocodec: libavcodec (960x512 fourcc=58564944 [DIVX])
    Writing header...
    ODML: Aspect information not (yet?) available or unspecified, not writing vprp header.
    1 duplicate frame(s)!
    Writing header...
    [h264 @ 0x878f8c]reference picture missing during reorder
    [h264 @ 0x878f8c]abs_diff_pic_num overflow
    [h264 @ 0x878f8c]decode_slice_header error
    [h264 @ 0x878f8c]concealing 1920 DC, 1920 AC, 1920 MV errors
    [h264 @ 0x878f8c]illegal short term buffer state detected
    h264.c:4128: failed assertion `h->long_ref_count + h->short_ref_count <= h->sps.ref_frame_count'
    /bin/sh: line 1: 14143 Abort trap: 6           '/Library/Application Support/ffmpegX/mencoder' /Users/Mesqueeb/Desktop/ponyo1.m4v -oac mp3lame -lameopts cbr:br=128:vol=0 -srate 48000 -aid 0 -ovc lavc -sws 0 -lavcopts threads=2:vcodec=mpeg4:vbitrate=940:keyint=240:vqmin=2:vqmax=15 -ofps 23.976 -vop scale=960:512 -noodml -ffourcc DIVX -o /Users/Mesqueeb/Desktop/ponyo1.m4v.ff.avi
    double
  9. Explorer Case's Avatar
    Next problem:
    It seems the H.264 video of your source file has some properties that this version of mencoder can't handle.
    Try an ffmpeg preset (e.g. "XviD ffmpeg"), see if it performs better.
    Next problem:
    That didn't work, but I got a work around: With Handbrake I converted it to a ffmpeg mp4 and not a H.264 format. And after that I was able to convert to avi! ^^
  1. Lagarith codec installation problem
    By kILLDR3n in forum Video Conversion
    Last Post: 18th Apr 2010, 20:17
  2. I have some problem with wvc1dmo installation.
    By Dboyz in forum Newbie / General discussions
    Last Post: 10th Sep 2009, 03:23
  3. FLVtool2 installation problem
    By linea in forum ffmpegX general discussion
    Last Post: 15th Dec 2008, 12:09
  4. Problem with the installation!
    By defacta in forum ffmpegX general discussion
    Last Post: 19th Jul 2007, 23:37
  5. installation problem
    By gokes in forum ffmpegX general discussion
    Last Post: 10th Jun 2007, 03:55
