Hey all, i've been having this problem for over a year now (i gave up 6 months ago and now trying yet again). What i'm trying to do is fit 5 small AVI tv shows which have been converted into DVD format onto one DVD. The problem i'm having is the VOB files which appear after the conversion all seem to have the same name and i can't seem to find out how to re-name so they are all different and can then be burnt onto one DVD disc. Please could you help. Many thanks.
Results 1 to 11 of 11
DeEp34, in the future please use a more descriptive subject title in your posts to allow others to search for similar topics. I will change yours this time. From our rules:
Try to choose a subject that describes your topic.
Please do not use topic subjects like Help me!!! or Problems.
Moderator redwudz
And welcome to our forums. -
Apologies Redwudz. Aedipuss, thanks for getting back to me on this. So i change each of the VOB files from each of the shows and rename them say..show1.mpg , show2.mpg and so on. Then put them all into one folder and convert to DVD, is this right? Many thanks again.
No. Use VOB2MPG to extract the content correctly, then you can rename the new files to something else.
How are you creating the VOBs ? If you encode and author properly then you won't have the problems you are having. The issues you have usually come form using poor quality tools like WinAVI for conversion, and not fully understanding the process.Read my blog here.
Originally Posted by DeEp34
You most likely need to start from scratch(the avi files). -
Thanks, i will try again tonight and get back to you either way. Thanks again.
ConvertXtoDVD will create basic menus and allow you to add several avi files for encoding. It is a better one-click solution than WinAVI.
If you are in love with WinAVI (and like people who love fat chicks, I don't understand it, but I accept that it happens), then you can use something like Tmpgenc DVD Author's add video function to create menus and bring everything together.
GUIForDVDAuthor can also be used.Read my blog here.
Hey all, everything seemed to be going good but it seems to be freezing my computer when left to convert using ConvertXtoDVD. I'm having to start from the begining every time i leave the computer, any ideas please.
help editing DVD / VOBs files
By mariano in forum Newbie / General discussionsReplies: 5Last Post: 7th Apr 2012, 21:01 -
22 VOBs to a single DVD with chapters
By paakkjo in forum Authoring (DVD)Replies: 3Last Post: 17th Dec 2009, 02:35 -
Convert non-compliant VOBs to "good VOBs"
By pmolson in forum Video ConversionReplies: 3Last Post: 24th Oct 2008, 11:52 -
Create DVD from several VOBs ?
By flash70 in forum DVD RippingReplies: 3Last Post: 8th Jun 2008, 10:51 -
Missing vobs on DVD
By stencil in forum Newbie / General discussionsReplies: 4Last Post: 13th May 2008, 00:17
