I have a h264 video in mp4 container.
I want to cut some portions of the video without re-encoding
I tried virtualdub but it does not recognise the file type.
please suggest any other software to do it.
Results 1 to 10 of 10
You could try MP4box. Note that it can only cut on keyframes.
MP4Box is a command line application. If you are looking fo a GUI to it, try Cut Assistant or YAMB.
HTH
Hi,
MPEG Streamclip or AviDemux will do what you want.
I'm trying to trim my clip, downloaded Streamclip and marked the in and out points, saved as another MP4 but the resulting file has 0 bytes. So Streamclip doesn't appear to work at all.
I just trimmed and joined some mp4-AVC-H.264 files from my Sanyo Xacti HD2000 camcorder using Mpeg Streamclip and it was a breeze!
Simply open the video files you want to join all at once or one after another (I think they'll need to have the same resolution, encoding etc).
If you choose "Export as mp4" it will re-code, so you need to select "Save As" from the FILE menu.
I know this thread is really old but it is still the first result on google when you search for "trim mp4 without re encoding". I just found this piece of software that worked magnificently.
http://www.dvdvideosoft.com/products...-Video-Dub.htm
It appears to be one of those video editing programs that is actually free with no strings attached. Just need to be careful when installing so you opt of of the browser tool bar it is bundle with.
What about SolveigMM Splitter? It's just been redesigned for H.264, works great.
Added Free Video Dub to our tools list.
MP4 h264/AVC editors with preview and lossless cutting:
Free:
Avidemux
Free Video Dub
Mpeg stream clip
Trials:
Solveigmm Video Splitter
Videoredo Tvsuite H.264
cutting Video Without Re-encoding
By stallion2008 in forum EditingReplies: 2Last Post: 30th Mar 2011, 17:03 -
Best way of cutting HD h264 MKV ?
By Torresinho in forum EditingReplies: 4Last Post: 3rd Jun 2010, 10:12 -
Cutting out a bit from an H264 video in an MKV container?
By PsyCLown in forum EditingReplies: 2Last Post: 4th Jan 2009, 10:04 -
Cutting video to several parts without encoding (on Unix system)
By Doctor_X3 in forum EditingReplies: 0Last Post: 23rd Feb 2008, 14:23 -
H264: Are there other h264 (AVCHD/VC-1) encoding command-line/CLI tools ??
By vhelp in forum Newbie / General discussionsReplies: 12Last Post: 16th Feb 2008, 01:20
