VideoHelp.com Forum
    I encoded a MOV. file to FLV. The size is 480x204 and it plays perfectly in preview at correct size. On my website it plays incorrectly at about 4x3 or less. The height seems ok but the width is much smaller.The autosize was set at 2.35:1. Also there is a white box within the video.How do I fix this?
    What tool are you converting with?
    What flv player are you using on your site?
    I'm converting .mov to FLV using ffmpegX encoder. I'm using the flash video in JAlbum with the Fotoplayer skin. I don't know what player is being used.
    I'm converting .mov to FLV using ffmpegX encoder. I'm using the flash video in JAlbum with the Fotoplayer skin. I'm using Adobe Flash Player 9. How can I fix this problem?
  5. Banned
    I think you need an FlV managing tool. which can help you encode and decode correctly.
    I had used a converter. It is farily nice. Maybe you need it too.
    You may download it from
    http://www.bidown.org/Multimedia-&-G...n-Version.html
  6. Mod Neophyte Super Moderator redwudz's Avatar
    Probably better in the ffmpegx forum. Moving you.
  1. Problem with window size when encode mov to flv
    By amedeop in forum ffmpegX bugs and suggestions
    Last Post: 16th Feb 2010, 17:23
  2. Insterting metadata to FLV videos on website
    By ftrcblais in forum Newbie / General discussions
    Last Post: 18th Jan 2010, 13:06
  3. FLV seems fuzzy on website
    By expertadvisor in forum Video Streaming
    Last Post: 23rd Sep 2009, 12:57
  4. Capture SWF / FLV from Website
    By foochuck in forum Video Conversion
    Last Post: 19th Feb 2008, 20:21
  5. size problem(edit youtube FLV in premiere pro)
    By yunakokimama in forum Newbie / General discussions
    Last Post: 25th Jun 2007, 09:52
