Hi,
I am working in CD Protection techniques, so for this i am using CDRWIN (demo version)
software with freelock-1.3 but i am getting
"Invalid CUE SHEET command at line 56 Illegal cuesheet command syntax"
and it wont burn.
Specifications :-
1. OS : Windows XP, SP1,CPU P(4),3.00GHz, RAM:1GB
2. CDRWIN :- 4
3. Demo version
4.Error:- Invalid CUE SHEET command at line 56 Illegal cuesheet command
syntax.
5.CDROM/Recorder :- Sony CD-RW CRX230ED
6. I am making an image.cue file from the CD content, it has been done
successfully but when & i am trying to record CD & click the load
cuesheet it shows the above error.
7. Recording speed :- max but for low slow speed it show the same error.
We are seriously thinking to buy this software, because we want protect
our CDs but before that my above problem has to be solved. Kindly reply me
asap.
Sarvagya Dwivedi
MTech, Elctrical Engg.
IIT Bombay,Powai,
Mumbai-400076
INDIA
email id:- sarvagya_dwivedi@yahoo.com
Results 1 to 17 of 17
Thread: CD protection techniques
you might want to contact the authors of cdrwin.
www.goldenhawk.com
and it's kinda hard to tell what the error might be without the actual command listed at line 56.--
Hi,
I sent them email four/five times but all are bounced back. What will i do.
Please suggest some technical suggestions so that i am moving ahead.
Regards,
Sarvagya
>>hard to tell what the error might be without the actual command listed at line 56.<<
Hi,
If you are already used this software(CDRWIN) with FREELOCK 1.3 for CD protection then kindly tell me the procedure if possible.
Regards,
sarvagya
it only works for vcds/svcds and also makes them non-compliant so they may not play in all players.
http://forums.xbox-scene.com/lofiver...hp/t77076.html
but anything you can burn on your computer people can find a way to copy.--
Is this the wrong forum? Because a problem with CDRWIN seems to me to have nothing to do with VCDEasy.
There are many other programs that can burn BIN/CUE files, so you don't HAVE to use CDRWIN. Try another burner and see if you still have problems. If not, maybe it's an issue with CDRWIN.
Finally, you should be aware that your discs still can be copied. It will just be harder to do so and it will discourage some people from copying them, but a determined, smart person will still be able to get around whatever you do. I see posts all the time from people in India who want to copy VCDs that are copy protected, so there certainly is an interest in this.
If you REALLY want to protect the disc's contents just do the following.
1. Take a screwdriver and while pressing hard on the bottom of the disc make 4 'X's. One at 12, 3, 6, and 9 o'clock.
That's it. No one will be making copies of the disc, of course the play compatibility drops to zero too.
Sorry, it's just that anybody who READS knows this topic has been talked to death and should know better.
Hi,
Let me know the solution if you have guys, i am struggling. Also i know if something is protected it should cracked one day. But can't its a big issue, i think we have work on it.
Aedipauss, the solution what you gave it me just go down in that forum one guy is suffering from same problem that i have.
I used the same above method & got this particular problem. Kindly, give me the solution if possible.
Regards,
Sarvagya
Hi sarvagya,
The first problem I had some years ago when I tried to copy protect my own vcd's with freelock and cdrwin was that cdrwin always displayed "cuesheet rejected by the cd-rom recorder" when I tried to burn the cue file. The solution to this problem was to burn in DAO96 mode.
The second problem I had was with freelock because the copy protection added by freelock wasn't that good and the reason for this was that freelock was never designed for copy protecting VCD's.
The only solution for me back then was to develope my own copy protection for VCD's.
vcd4ever.
Ooops, I clicked on the "quote" button instead of the "edit" button.
vcd4ever.
Hi VCD4ever,
First i am thankful to you bcoz of your reply. What is this DAO96. Could you plz explain your own method for CD protection if possible.
I am waiting for your reply because believe me nothing works & i am in big trouble.
Regards,
Sarvagya
DAO96 is simply put a special burning mode that allows you to burn a CD with for example "unreadable sectors" and/or "illegal TOC".Originally Posted by sarvagya
It's going to be to complicated for me trying to explain how my copy protection is done and how it works.Originally Posted by sarvagya
I have however here "File Deleted" a VCD sample with my copy protection that you can download and burn to a CD.
I hope that this VCD sample will at least give you an idea on how a VCD can be copy protected when burned in DAO96.
vcd4ever.
What is this? Give me some pdf link if possible for you.
Sarvagya
I'm sorry, but that's totally imposible because I have developed my own copy protection from scratch without the help from any documents.Originally Posted by sarvagya
I'm also sorry that my VCD sample was of no use.
vcd4ever.
So kindly tell me your procedure if you don't have problem to disclose it
Sarvagya
VCD4ever ,
Can you please tell me your procedure to protect V CDs . I am great full to you
Regards,
Sarvagya
About Camera Techniques
By ayim in forum Newbie / General discussionsReplies: 12Last Post: 10th Dec 2009, 11:22 -
Multimedia Techniques -- Comparison
By Dave1024 in forum Newbie / General discussionsReplies: 6Last Post: 6th Nov 2009, 00:30 -
A/V out of sync, despite using various techniques
By takearushfan in forum DVD RippingReplies: 4Last Post: 7th Jul 2009, 00:24 -
discuss ogg theora techniques
By zoobie in forum Video ConversionReplies: 11Last Post: 25th Aug 2008, 12:32 -
Looking for the best scanner/techniques for pictures
By PharmBoy in forum Newbie / General discussionsReplies: 10Last Post: 19th Jul 2007, 23:17
