What is the minimum system requirement to play x264 files?
Thread: system requirement for x264
My guess is the appropriate codec. How well they play is up to the processor, RAM, bus speed...
Looking at your CPU (Athlon 2000), I'd say you're (barely) in the ballpark but I'd definitely beef up your RAM to 1GB.
I can play x264 very fine even in full screen. Just asking cause I wanted to put that in my site FAQ
Depends on the frame size.
Same requirements as any other AVC. Depends as said on framesize, also what decoder you are using and whether you are using hardware acceleration or not. For instance CoreAVC uses less resources than ffdshow and is multithreaded, but then if you have an 86/500 video card you should be able to offload all the decoding to the card. Same goes for AMD's latest cards. Lastly it also depends on what encoding profile. High Profile will require more power to decode than Base Profile.
Bitrate vs Size Calculator for x264 for ripping DVD to x264 + AC3
By Bonie81 in forum DVD RippingReplies: 7Last Post: 5th Jul 2010, 18:24 -
H.264 MOV Requirement
By NautTboy in forum Software PlayingReplies: 3Last Post: 14th May 2010, 18:55 -
Best laptop to meet High Definition(AVCHD) video editing system requirement
By Michelle Sheen in forum ComputerReplies: 1Last Post: 5th Apr 2010, 22:21 -
Newbie ?: SDHC requirement and HD recording
By carlsjunior99 in forum Camcorders (DV/HDV/AVCHD)Replies: 1Last Post: 30th Mar 2010, 15:45
