So I was converting a VOB file of a dvd that I have, and after it converted, it split the mp4 file into two files, one was a video.mp4 which had the video of the dvd on it and it ran just fine, there was just nothing to listen to. The second file was a audio.mp4 file and it was 0kb large and had nothing on it. What am I doing wrong and how can I get audio and video onto the same mp4 file???
Please post the results of the encoding (the "i" button) and it should provide some info from which we can determine the problem.
unfortunately i cleared the list, so i will have to re-encode the file and then i will post what it says.
On the second time of encoding, it gives me only one mp4 file, but it cannot be played. But I am not sure that it has stopped encoding. It read 101% when I went to check the file, but now it says 102%. . .
Now it says finished, and again, there are two mp4 files. One video, one audio. Video works, no sound, audio file won't even open.
here is the process info
Encoding started on Thu Jul 12 10:04:28 EDT 2007
FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
Mac OSX universal build for ffmpegX
configuration: --enable-mp3lame --enable-gpl --disable-vhook --disable-ffplay --disable-ffserver --enable-a52 --enable-xvid --enable-faac --enable-faad --enable-amr_nb --enable-pthreads --enable-x264
libavutil version: 49.0.0
libavcodec version: 51.9.0
libavformat version: 50.4.0
built on Apr 15 2006 08:41:02, gcc: 3.3 20030304 (Apple Computer, Inc. build 1666)
x264 [info]: using cpu capabilities Altivec
mp4 [info]: initial delay 0 (scale 24000)
Input #0, mpeg, from '/Users/Desktop/NAPOLEON_DYNAMITE_SE_D1 Title 1/VIDEO_TS/NAPOLEON_DYNAMITE_SE_D1 Title 1.VOB':
Duration: 00:54:47.1, start: 0.203578, bitrate: 15624 kb/s
Stream #0.0[0x1e0], 29.97 fps(r): Video: mpeg2video, yuv420p, 720x480, 9800 kb/s
Stream #0.1[0x20]: Subtitle: dvdsub
Stream #0.2[0x21]: Subtitle: dvdsub
Stream #0.3[0x22]: Subtitle: dvdsub
Stream #0.4[0x23]: Subtitle: dvdsub
Stream #0.5[0x24]: Subtitle: dvdsub
Stream #0.6[0x25]: Subtitle: dvdsub
Stream #0.7[0x26]: Subtitle: dvdsub
Stream #0.8[0x27]: Subtitle: dvdsub
Stream #0.9[0x80]: Audio: ac3, 48000 Hz, 5:1, 448 kb/s
Stream #0.10[0x81]: Audio: ac3, 48000 Hz, stereo, 192 kb/s
Stream #0.11[0x82]: Audio: ac3, 48000 Hz, stereo, 192 kb/s
Stream #0.12[0x83]: Audio: ac3, 48000 Hz, stereo, 192 kb/s
Stream #0.13[0x84]: Audio: ac3, 48000 Hz, stereo, 192 kb/s
Output #0, yuv4mpegpipe, to 'pipe:':
Stream #0.0, 23.98 fps(c): Video: rawvideo, yuv420p, 640x352, q=2-31, 200 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Press [q] to stop encoding
video:0kB audio:0kB global headers:0kB muxing overhead inf%
x264 [info]: slice I:1275 Avg QP:19.24 size: 28172 PSNR Mean Y:44.88 U:47.70 V:48.15 Avg:45.62 Global:45.20
x264 [info]: slice P:135101 Avg QP:22.37 size: 3078 PSNR Mean Y:42.71 U:46.37 V:46.82 Avg:43.53 Global:42.84
x264 [info]: mb I I16..4: 25.5% 0.0% 74.5%
x264 [info]: mb P I16..4: 2.5% 0.0% 2.0% P16..4: 46.1% 0.0% 0.0% 0.0% 0.0% skip:49.4%
x264 [info]: final ratefactor: 20.78
x264 [info]: PSNR Mean Y:42.725 U:46.378 V:46.835 Avg:43.553 Global:42.856 kb/s:635.30
encoded 136376 frames, 5.19 fps, 636.32 kb/s
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/Users/Desktop/NAPOLEON_DYNAMITE_SE_D1 Title 1/VIDEO_TS/NAPOLEON_DYNAMITE_SE_D1 Title 1.VOB.ff.video.mp4':
Duration: 01:34:48.0, start: 0.000000, bitrate: 637 kb/s
Stream #0.0(und), 23.98 fps(r): Video: h264, yuv420p, 640x352
Input #1, mpeg, from '/Users/Desktop/NAPOLEON_DYNAMITE_SE_D1 Title 1/VIDEO_TS/NAPOLEON_DYNAMITE_SE_D1 Title 1.VOB':
Stream #1.0[0x1e0], 29.97 fps(r): Video: mpeg2video, yuv420p, 720x480, 9800 kb/s
Stream #1.1[0x20]: Subtitle: dvdsub
Stream #1.2[0x21]: Subtitle: dvdsub
Stream #1.3[0x22]: Subtitle: dvdsub
Stream #1.4[0x23]: Subtitle: dvdsub
Stream #1.5[0x24]: Subtitle: dvdsub
Stream #1.6[0x25]: Subtitle: dvdsub
Stream #1.7[0x26]: Subtitle: dvdsub
Stream #1.8[0x27]: Subtitle: dvdsub
Stream #1.9[0x80]: Audio: ac3, 48000 Hz, 5:1, 448 kb/s
Stream #1.10[0x81]: Audio: ac3, 48000 Hz, stereo, 192 kb/s
Stream #1.11[0x82]: Audio: ac3, 48000 Hz, stereo, 192 kb/s
Stream #1.12[0x83]: Audio: ac3, 48000 Hz, stereo, 192 kb/s
Stream #1.13[0x84]: Audio: ac3, 48000 Hz, stereo, 192 kb/s
Codec type mismatch for mapping #1.1 -> #0.0
if anyone could tell me how to use ffmpegx to convert a VOB file to an MP4 file, that would be great too, because i checked the how to section, but i couldn't find a real solution to my problem. I would love anyone's advice.
i thought i would add that i am using the h.264 conversion
Go to the audio tab and change the Audio Track pull down to 8. I recently had this problem as well. Ffmpegx thinks the first few streams are audio tracks, but they are really subtitle tracks.
You could even set the dimensions to 16x16 with 200kbps bitrate and do a quick encode of a few of the audio tracks until you find the right one.
Problem converting combined motion jpeg and mp4 audio file into other forma
By cezary.rataj in forum Video ConversionReplies: 49Last Post: 31st Aug 2011, 16:14 -
How to add an mp3 audio file onto an mp4 video file?
By Tintin11 in forum RestorationReplies: 4Last Post: 4th Nov 2010, 06:01 -
Avidemux - DVD/VOB file to MP4/MKV - Audio problem
By prabath_fun in forum Video ConversionReplies: 0Last Post: 7th Sep 2010, 10:32 -
Conversion from VOB-File into a MP4 File stopps after 9 minutes...
By Fly Eagle in forum ffmpegX general discussionReplies: 2Last Post: 6th Aug 2009, 11:41 -
Problems converting MP4 video file to DVD.
By teapot in forum Newbie / General discussionsReplies: 7Last Post: 6th Oct 2008, 18:26
