VideoHelp.com Forum
Results 1 to 12 of 12
    I notice that after installing automatic updates my XP PRO went down to a XP. At least I don't see Professional at start up or on my desktop. I am concern if this is affecting functionality of my OS in anyway. I know updates can be done manually if needed, so my question is why do auto updates in the first place? I mean "they" can pretty much do anything what they want with your computer without your knowledge or approval.
    moved to another forum, nobody likes me here...
  2. Mod Neophyte Super Moderator redwudz's Avatar
    You can easily turn off updates, or maybe better set them to download but not install until you inspect and approve them. MS updates seem to download a lot of useless crap for MS programs you may not have or don't ever use on your computer.
    I wouldn't worry to much about the Windows splash screen. But if you go to 'Control Panel>System' you should see 'Microsoft XP Professional' there.
    Pro and Home are basically the same OS. Pro has better encryption and some more networking tools and some other options that 90% of us would probably never use, but otherwise very little difference. Here's a quick comparison between the two OS versions: http://www.microsoft.com/windowsxp/p...choosing2.mspx
    I notice that you can shut down any thread with the first reply
    For reasons only know to MS, the Pro went away on the splash screen with SP2. It still is Pro though if that was what you initially installed.
  5. Member Skith's Avatar
    Not if I have anything to say about it, and I do! :P
    Personally, I don't touch online/windows updates. www.autopatcher.com - the greatest thing for windows users since sliced bread.
    Be sure to read the FAQ and look at the forums, you can find answers to most questions. This program is also a huge time saver when you have a freshly installed version of windows, since all updates are contained in a single package. It allows the user to chose what updates to install (nothing is done without permission). A description and KB link are provided about each individual patch.
    Some people say dog is mans best friend. I say that man is dog's best slave... At least that is what my dogs think.
  6. Member ranchhand's Avatar
    Amen, bro, Amen!! All I ever needed was SP2 and PCcillin along with my D-Link router firewall.
    It went from XP Pro to just XP for the same reason schools are now not giving out awards for kids. Giving one kid an award makes the other kids not getting one feel bad.
    In this case Microsoft users with 'just' XP felt inferior to those with XP Pro. This simply appeases the XP users and makes them think they're just as good. Or, at least, don't know that there's a difference. They now feel just as special as the XP Pro users.
    Have a good one,
    neomaine
    NEW! VideoHelp.com F@H team 166011!
    http://fah-web.stanford.edu/cgi-bin/...teamnum=166011
    Folding@Home FAQ and download: http://folding.stanford.edu/
    Just for that reason I'll re-install it again and tell them updates to go f... themselves
    BTW...it is a communist rule to make everyone equal...
    Are you the same flytrap running 4 firewalls? It is still XP Pro. Only the startup splash screen doesn't say so. All the features are there and if you right click on MY computer and pick properties it still shows there and so on.
    It sounds like you would rather have a insecure PC that say XP Pro tna one that has the newer Sps and is more secure.
    Firewalls will not keep you from getting infected by webpages due to unpatched security vulnerabilities.
  11. Member Rich86's Avatar
    I never, ever permit anything to autmatically update anything in my computer, including (how about especially) Microsoft. But I promise it has nothing to do with whatever opening logo screen Microsoft happens to display at boot. Somewhere along the way, one of the security updates or service packs must have swapped out the old XPPro logo screen for the current more generic XP - maybe the sp2 update?
  12. Member buttzilla's Avatar
    Or you could go to add/remove programs and uninstall all the updates.
  1. Replies: 23
    Last Post: 8th Aug 2009, 17:15
  2. Replies: 0
    Last Post: 5th Jul 2009, 07:44
  3. AVG 8 updates?
    By wulf109 in forum Computer
    Last Post: 3rd Feb 2009, 09:49
  4. Updates wont Download
    By bryankendall in forum Computer
    Last Post: 12th Nov 2008, 12:42
  5. strange updates
    By Tom in HD in forum Mac
    Last Post: 19th Feb 2008, 20:29
