VideoHelp.com Forum
    As the title states, the tray on my player is locked shut. I used the DVD player one night, went to use it on another and the tray wouldn't open. When the eject button is pressed, the "open" text appears on the player and a motor can be heard spinning. However, the tray doesn't open. When the button is pressed again, the player reads "loading," just like normal. It seems like the player doesn't "know" that anything is wrong. I tried opening it up and looking briefly at the drive while it attempts to open the tray, but I can't see anything obviously wrong. I'm at a loss as to what happened between one night and the other...
    Any ideas as to what might be wrong / how to fix it?
    By the way, I tried to do a factory reset, but that didn't do anything...
  2. I've had this happen on one DVD player before and it was just that the little plastic gear on the motor shaft, the gear that drives the tray in/out, had cracked, so it was just spinning on the shaft under load. I unscrewed the motor from the assembly, slid the cracked gear off (it just slides off), put a drop of super glue on the end of the shaft and slid the gear back on.
    Let it dry for a minute, screw the motor back in, and test it. It worked for me, hope it works for you!
    EDIT: Obviously you'll have to open up the player to do all this, and hunting down which screws to remove is half the fun. But make sure you only do this with the DVD player unplugged, it ain't worth getting fried for this!
  1. Toshiba SD-V295KU - locked tray - SOLVED!
    By Stiiv in forum DVD & Blu-ray Players
    Last Post: 23rd Dec 2010, 00:52
  2. Elby Tray Window
    By cyflyer in forum Newbie / General discussions
    Last Post: 12th Oct 2008, 09:21
  3. Problem with Norcent DVD Player, Tray keeps open/closing, tray disc error
    By daveshostack in forum DVD & Blu-ray Players
    Last Post: 12th Feb 2008, 11:41
  4. Mv DVB418 is dying. Need recommendations for replacement
    By kruuth in forum DVD & Blu-ray Players
    Last Post: 4th Feb 2008, 10:54
  5. DVB418 Upconvert issues?
    Last Post: 24th Jan 2008, 09:21
