hello
I would like some help on regarding a film i shot on my mini dv camcorder. I was shooting outside in bright sunlight i had the backlight compensation feature switched on, i forgot to turn it off & went inside a doorway which was dark still shooting the images outside in the sunlight, those images are washed out ( not sure if the correct term is over or under exposed ). My question is can i fix these problems with Adobe Premier 2.0?
Also when i hit the capture button the sound judders ( when playing back through the camcorder sound is fine ) when i play back, is this normal? will the juddering record when i burn it on to dvd?![]()
Thanks in advance
Thread: images over/under exposed help
Using conventional filters in Premiere or other NLEs will have limited effect. You will probably have to look at something more specialised. This thread : http://forum.videohelp.com/topic332734.html : covers a similar problem and offers some help, if not a lot of hope. It really depends on whether or not you have any room to work in.
Ok after reading the thread it would seem i need professional help with the image, but is the juddering(stuttering) sound normal?
Very 1st time exposed to straight AVCHD footage: HELP !!
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 5Last Post: 31st Jul 2011, 17:37 -
images
By AlanHK in forum TestReplies: 4Last Post: 4th Mar 2010, 13:12 -
thumb images yet?
By catdaddio6 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 18th Apr 2009, 02:02 -
HD images
By toneystone in forum Newbie / General discussionsReplies: 3Last Post: 21st Oct 2008, 11:50
Statistics
Newest guides
Latest tool updates
New media comments
