I have a DVD with no chapter points and I want to insert them at exact spots that i've determined. can i do this with PGCedit?
ken
Thread: new chapter points in PGCedit
Hi-
The easiest way I know to do this is to first demux the video using PGCDemux. Edit the Celltimes.txt to add in the chapters. Then remux using Muxman. Add in the Celltimes.txt in File->Import Chapter. Note that the Celltimes.txt uses frame numbers based on the output framerate of the DVD. For PAL this means 25fps and NTSC means the 29.97fps frame numbers. Since PGCEdit itself only supports them in that format, then maybe that's the way you made them (but something tells me that's not true). If you have the chapter points in some other format (like times), then reauthor using whatever authoring app that supports chapters in that particular format. Once you have the new Muxman (or some other program) authored DVD, assuming there's other things in the DVD you want to keep, such as menus and/or extras, open the original DVD in PGCEdit, highlight the original chapterless video, go File->Replace VTST titles, and follow the instructions from there. -
Why do not you get DVD Remake. It is not free, but you can create chapters without all those steps all in one program.
Here's a simple guide how to do it without demuxing:
http://www.dimadsoft.com/dvdremakepro/ht_insert_chapter.php
With DVDRemake you don't need to learn the program itself; while using it, you just learn DVD structure and navigation commands presented there in friendly form. Also good reference info in help file. -
Heck, if you want to do it that way, VobBlanker can do exactly the same thing, do it more easily and quickly, and doesn't cost a dime.
Open the DVD in VobBlanker, highlight the video so it appears in the lower screen, hit "Cells" to the right, and in the new screen that opens up, highlight the single cell and hit "Split". Then have fun, creating up to 33 chapters from the original single cell.
create chapter breaks that return to menu afterwards using PGCedit ?
By spiritgumm in forum Authoring (DVD)Replies: 7Last Post: 8th Feb 2009, 09:07 -
Buggy chapter transitions with PgcEdit Play All scheme
By ajrecs in forum Authoring (DVD)Replies: 2Last Post: 11th Oct 2008, 07:00 -
Pgcedit to go to main menu after a specific chapter?
By redsandvb in forum DVD RippingReplies: 4Last Post: 15th May 2008, 19:32 -
Moving Chapter Points?
By netmask56 in forum Authoring (DVD)Replies: 2Last Post: 3rd Jun 2007, 20:33
