VideoHelp.com Forum
  1. Member stewiegriffin711's Avatar
    I'm trying to install the latest Vob2mpg but I get the error message:
    Chrissy, are you out there?
    Thanks in advance.
  2. Member t0nee1's Avatar
    Did you uninstall previous version? are you logged in as administrator? during install enable all users for program... Where did you DL from?
    "I typed the word Google into Google. Guess what came up? Everything."
    "What we've got here is failure to communicate"
  3. Member stewiegriffin711's Avatar
    Yes to all 3 questions and I downloaded straight from the link on VideoHelp.com.
    Stew.
  4. Member ChrissyBoy's Avatar
    I think it is a funny with Windows Installer... Can you move the setup and msi file to the root folder and retry?
  5. Member stewiegriffin711's Avatar
    I knew you were out there ChrissyBoy!
    I tried installing it from c:\ like you suggested and I received exactly the same message.
    Stew
  6. Member ChrissyBoy's Avatar
    Like i said i have seen this before and it is a MSI weird one.... (http://www.google.co.uk/search?sourc...c%22+installer)
    But i found this:
    open a Command Prompt and cd to the folder where you saved the downloaded Setup_WindSim.msi file. Run the msiexec program as follows: msiexec /qb /I Setup_WindSim.msi
    replacing the name of the msi file - can you give this a try?
  7. Member stewiegriffin711's Avatar
    I ran "msiexec /qb /I c:\VOB2MPGSetup.msi" from the command line and worked!
    I have never had this problem before and I install/test/uninstall many programs over the years.
    Thanks for your help ChrissyBoy. You always come through!
    Stew
  8. Member ChrissyBoy's Avatar
    Like i said.... its a weird one!
  1. Problem with VOB2MPG - OverflowException error
    By Rod.G in forum SVCD2DVD & VOB2MPG
    Last Post: 31st Mar 2011, 05:04
  2. Need help with VOB2MPG. Error Message.
    By marcos77 in forum SVCD2DVD & VOB2MPG
    Last Post: 18th Sep 2010, 14:53
  3. Unable to install VOB2MPG or VOB2MPG PRO
    By tooc in forum SVCD2DVD & VOB2MPG
    Last Post: 28th Mar 2010, 00:53
  4. VOB2MPG 3.0.060 Error
    By SWBisbee in forum SVCD2DVD & VOB2MPG
    Last Post: 22nd Sep 2009, 09:41
  5. VOB2MPG error
    By dswofford1 in forum SVCD2DVD & VOB2MPG
    Last Post: 29th Jan 2009, 15:04
