VideoHelp.com Forum
  1. I bought an IO Magic 16X Internal DVD ReWritable Drive (Dual Format Double Layer) at staples. I believe it is actually an LG drive (LG GSA H22N). I cannot seem to get the drive to perform at more than 4X. I am using Nero and am not sure if there is a speed optimizer in it I should use. I did get the latest firware from LG (GSA-H22N_102.zip) but that didn't speed it up after I flashed the drive. I also got 16X media with no change.
    Could someone give me some tips> Drive seens to run fine, just not as fast as I had hoped.
    Mike
  2. DVD Ninja budz's Avatar
    Are you sure it's a LGH22N drive? Because the LGH22N drive isn't a 16x dvd burner, it's a 18x drive. Your drive could be a BENQ 1640 or 1650. Did the sticker on the drive say LGH22N? STAPLES used to sell the I/O MAGIC 16X dvd internal drive which were rebadged BENQ 1640 or 1650 drives or they could also be LITEON drives as well.
    What brand of media are you using? Try using VERBATIM or TAIYO YUDEN dvd media and burn with IMGBURN instead of NERO.
  3. DVD decrypter is also quite a good burner for iso images.
    Check pio mode and ide mode.
    delete ALL dvd drives under XP , then reboot and let Xp re-create the device descriptions from scratch.
    16x drive will only burn at 16x on correct media and only for a small portion of the burn (25%?) cav/clv
    Below is a correct 16x burn (1200 pio errors)
    The electronic components of the power part adopted a lot of Rubycons.
  4. DVD Ninja budz's Avatar
    DVD DECRYPTER is NO LONGER UPDATED. It would be best to use IMGBURN to burn ISO images. Both of those programs were created by the same author, LightningUK.
  1. Verbation 16x and GSA-S10N drive
    By webstar in forum Mac
    Last Post: 23rd May 2010, 00:15
  2. Verbatim 16X DVD+R still good?
    By d3xter in forum Media
    Last Post: 21st Aug 2009, 13:32
  3. Question on readability of Imation DVD-R 16X
    By Dofod in forum DVD & Blu-ray Recorders
    Last Post: 22nd Dec 2008, 12:14
  4. help, for read dvd disc with 16x
    By flowerhorn in forum Newbie / General discussions
    Last Post: 29th Jul 2008, 09:35
  5. Office Depot Brand 16X DVD
    By gameroftheuk in forum DVD & Blu-ray Writers
    Last Post: 28th Sep 2007, 23:55
