VideoHelp.com Forum
Results 1 to 9 of 9
  1. Member Webster's Avatar
    Does anyone know if there is a mounter like Daemon Tools for Linux?
  2. Mod Neophyte Super Moderator redwudz's Avatar
    Take a look at CDemu: http://cdemu.sourceforge.net/
  3. Member Webster's Avatar
    Thanks, I'll give it a try.
    You really do not need special tools on linux or unix like OSes for mounting image files.
    If the image is an ISO, you can mount it using the mount command itself.
    mount -o loop image-file.iso /mnt/mount-directory
    Of course depending on the image type, you have to tell the mount command what type of image it is. Example if it is a Apple image (dmg), then hfs
    mount -t hfs -o loop image-file.dmg /mnt/mount-directory
    -GGR
  5. Member Webster's Avatar
    -GGR
    Thanks for the info. It has been more than 20 years since my Unix days. I'd guessed what they said is true. If you don't use it, you loose it....
    Gmount-iso
    Hello Webster,
    just found acetoneiso at
    http://www.acetoneiso.netsons.org/
    Good Luck
    i've used cdemu before. it's not too bad. I would say use the built in loop mount for iso files. You can convert others to iso pretty easily (nrg2iso and others). cdemu is versatile (sp?).
  9. Mr. Computer Geek dannyboy48888's Avatar
    if you trying to do 'dvd' images the it wound be mout -t iso9660 -o loop 'image name here' /mnt/'your mount point'
    most dvd's have a iso9660 and a udf section. most apps play nice with the iso9660 option though
    if all else fails read the damn manual
  1. Daemon Tools Pro 10 gives Error code 6
    By Benjy in forum Computer
    Last Post: 30th Jul 2010, 00:01
  2. DAEMON Tools Pro Standard - free today only
    By aedipuss in forum Latest Video News
    Last Post: 23rd Jul 2010, 10:12
  3. Replies: 1
    Last Post: 5th Oct 2009, 21:25
  4. Daemon Tools can slow rip speed
    By ocgw in forum Blu-ray Ripping
    Last Post: 29th May 2009, 06:09
  5. Daemon Tools for Vista
    By mysts in forum Newbie / General discussions
    Last Post: 27th Jul 2007, 19:13
