I have looked around but have not found a way to do this on my mac.
I have a short MPG file created with a Sony Cybershot. The camera was held sidways and i need to rotate the video 90 degrees.
Thread: Changing Video Orientation
Sometimes I doubt your commitment to Sparkle Motion.
Hi,
You can rotate the movie with SimpleMovieX and save it without quality loss in QuickTime mov format.
http://www.aeroquartet.com/SimpleMovieX/
Regards, BJ
(Note that I'm the developer of this little app) -
I believe you'll find that rotating the movie will result in
lack of sound. Look at Window/MovieProperties in QuickTime.
I expect you'll see MPEG1 MUXed.
You need to convert to deMUXed (separate audio and video)
streams. The $23 VisualHub does that easily. Get it from this
link http://www.isquint.org/. Then QuickTime Pro can rotate
the clip.
And AeroQ is right. SimpleMovieX ($30) does the rotate
quite nicely (keeping sound) in one step. I just tried it
on a clip from Leslye's Sony camera.Al Bloom -
I just want to say thank you to AeroQ.
I came here tonight with this same question and
found this thread. Downloaded SimpleMovieX
and was able to very quickly rotate some video
that I shot at a wedding last week.
Thank you also for a fully operational demo...you
don't find many these days.
I will be purchasing this app soon
Question about DVD Authoring - Adding subtitles in a vertical orientation
By djash1983 in forum Authoring (DVD)Replies: 1Last Post: 31st Oct 2010, 20:56 -
Video orientation is not completely horizontal as intended/Help!
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 6Last Post: 2nd Aug 2010, 10:45 -
Changing the PAR of a video
By prestonfaiks in forum Video ConversionReplies: 1Last Post: 27th Apr 2009, 12:56 -
changing orientation of video
By yadda in forum Newbie / General discussionsReplies: 1Last Post: 25th Aug 2008, 12:21 -
Changing Video Resolution
By Erf in forum Newbie / General discussionsReplies: 4Last Post: 25th Aug 2007, 22:16
