VideoHelp.com Forum
    Can anyone help me find a program or tool that will allow me to capture DVD footage from a Disc I have already made?
    I am trying to go back and author a new improved version of some old footage I had already imported from my camcorder. I no longer have the DV tapes to import from the Cam, so I will have to pull them directly from the DVDs themselves.
    I would like to find a program or utility that will allow me to use the DVD-Rom in my PC as the device to capture from. I have NEVER seen anything that will do this, but I think there must be one.
    HELP???
  2. Mod Neophyte Super Moderator redwudz's Avatar
    Sure, just copy the authored DVD files to your hard drive. You don't need any programs or need to do any 'capturing'. Or you can use DVD Decrypter if you want more control over the process. Or if you just want the MPEG part of the DVD for reauthoring, use VOB2MPEG.
    Unless you have something different in mind.
    If they are in DV format instead, same thing, just copy them to your hard drive and treat like any other file.
  1. Replies: 5
    Last Post: 29th Oct 2010, 09:43
  2. Replies: 11
    Last Post: 25th Jul 2010, 15:58
  3. Can someone direct me to a good capture device..
    By KameronK in forum Capturing
    Last Post: 28th Mar 2008, 21:46
  4. DV Direct to DVD (DV Capture)
    By coisty1856 in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 13th Sep 2007, 14:15
  5. Capture / Burn direct to drive
    By Bob08 in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 19th Jul 2007, 15:28
