I have a Philips DVDR 3390. I'd like to, if possible, use it to capture DVDs to a PC using Firewire (i.Link). Does anyone know if this works? Can it be hacked to do such a thing?
If not, any cheap solutions around that can convert analog to DV without buying an expensive deck or camera?
Thanks!
Consumer level DVD recorders with FireWire are strictly for input only. i.e., you can take DV from a camcorder and record it to DVD. You can't play a DVD and get DV out of it.
As you suggest, you really need a DV camcorder with analog pass-through. You can find some bargains on eBay. Since you aren't interested in the camera function, any cheap one will do (though do verify it can do pass-through). I picked up a decent camcorder for $200. I just needed the LCD panel to repair a more expensive one. But now I have a fully functional analog-to-DV converter, too.
Alternatively, you can get converter boxes that do nothing but convert analog to DV and vice versa. Cost varies.John Miller
enosoft - high performance tools for music and video
Home of the Enosoft DV Processor - Free for personal use!
Can you suggest a converter box for under $200? I'd like it to have component and s-video. and of course, audio.
Datavideo DAC-200 for about $190.
http://www.dvwarehouse.com/Datavideo...V-p-32197.htmlJohn Miller
Out of curiosity, is there some reason why you don't want to simply put the disc into the computer's DVD drive and read it directly?Originally Posted by muzicman82
I fixed my Philips DVDR 3455H dvd/hdd recorder
By dphirschler in forum DVD & Blu-ray RecordersReplies: 48Last Post: 26th Feb 2011, 18:40 -
Philips DVDR-3480 DVD Recorder and Player 1080iâ€
By Vixfoxwatch in forum Newbie / General discussionsReplies: 5Last Post: 7th Nov 2010, 14:18 -
Philips DVDR 3390 won't let me fast forward DivX movies
By guiri in forum DVD & Blu-ray PlayersReplies: 0Last Post: 21st Sep 2007, 03:28 -
DVD Recorder Philips DVDR 3475/37. Help-me with region free.
By Aurelio in forum DVD & Blu-ray RecordersReplies: 1Last Post: 4th Sep 2007, 13:04 -
Philips DVD 160GB Recorder Model DVDR 3455H
By vsenapati in forum DVD & Blu-ray RecordersReplies: 2Last Post: 28th Jun 2007, 19:56
