    May 2006
    What can I use to watch avi videos on a SD card on my TV. Is there a inexpensive
    interface?
    I want to watch videos from my digital camera as well as other avi videos on my TV.
    thanks
    Ken
    Aug 2007
    Australia
    Okay, best i can think of is to get yourself a Divx/Dvd Player which has slots for memory cards or a USB port. It's much to hard to find a TV which has a reader in it already so this is probably your best bet.
  3. Banned
    Freedonia
    Do note that the following options may or may not be problems in playing Divx/Xvid on a DVD player:
    1) GMC
    2) QPel (Quarter pixel)
    3) Packed bitstream
    4) Resolutions greater than 720x576
    5) Bitrates higher than 2000 Kbps.
    If any of these issues cause playback problems for you, you'll have to re-encode. Well, you can fix packed bitstream with MPEG4Modifier without re-encoding, but you'll have to re-encode to fix any problems with the other 4.
    If you want to connect your PC to a TV to watch the videos, that would eliminate the problems I listed. You'll need either a TV out option on your PC TV card or some kind of cable to connect your SD TV to your PC.
    May 2007
    reality
    Does your camera have a video out port? If so, connect it to your TV and play the videos on the camera. The connection is usually composite and the video low-resolution so don't expect stunning reults...but it's an inexpensive interface.
    If your camera can connect to your computer, transfer the AVI files to your computer. Or use an SD card reader to handle the task. You can watch the videos on your computer. If you have a DVD burner you can then encode the AVI's to DVD format and burn video DVD(s) of them. You can then watch them on a DVD player connected to your TV but your profile does not list a DVD player so you would probably have to buy one...a bit more expensive.
    Or build an HTPC and output to your TV...but that would be expensive.
    VH
  5. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    interface?
    Your TV accepts SD cards? What does the manual say about video formats accepted?
    In my experience, these cards are only supported for JPG slideshows and MP3 audio.
    Aug 2007
    I have a LG DVD player with an sd card slot and divx avi mpg compatabillty.
    The model number is LDA 511 I think I got it at circuit city.
    I think it cost me $150 when I bought it but that was 2 years ago.
    My question I have is about subtitles wondering if I could add subs to the SD card and make it work.
  7. Member edDV's Avatar
    Mar 2004
    I'm not familiar with divx subtitles modes but you could encode divx with subtitles burned in.
    http://www.kiva.org/about
  8. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Not that many DVD players handle muxed subtitles. Best bet would be to use .srt subtitles, with the same name as the video; movie.avi + movie.srt in the same directory.
    On some players (like mine) you have to first select the subtitle file, then start the movie; Some will automagically pick up the subtitles using the "same name" principle.
    /Mats
