I dowloaded 3 separate AVI files which together make a full show. In the 2 first videos the audio is out-of-sync, it goes faster than video. The third one is ok. How can I fix the 2 first vids?
I haven't needed to do this yet myself, but you need to multiplex (or is it demultiplex, I alwasy confuse the two) the video. What that means is separate the audio from the video. Once you have done this, you can use a program to adjust the length of the audio to match the video, ie. slow down the audio. As I haven't needed to do that yet, I'm not sure which program will do it for you, but I'm sure there are people on here that will know. I think Womble Video Wizard is one that might do it.
Before you do anything too silly, you have to work out what type of sync problem you have. You only need to stretch the audio if the audio sync changes over time. Most of the time the sync problem is constant, it just starts too early or too late, in which case you just have to change the start point of the audio.
Read this post : https://forum.videohelp.com/topic316884.htmlRead my blog here.
Originally Posted by guns1inger
How to sync the dubbed audio to make a dual audio .avi
By Scotter in forum AudioReplies: 4Last Post: 24th Dec 2011, 15:17 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 16:14 -
fix audio sync in dual audio avi
By jin007 in forum Newbie / General discussionsReplies: 2Last Post: 19th Jul 2008, 10:07 -
audio out of sync from avi
By theft in forum ffmpegX general discussionReplies: 1Last Post: 13th Nov 2007, 22:32 -
Converting AVI to xvid AVI - Audio Sync Problem
By foochuck in forum Video ConversionReplies: 3Last Post: 4th Jul 2007, 23:22
