VideoHelp.com Forum
  1. Originally Posted by trossin
    .tar files are usually UNIX Tape ARchive files. You will need to untar it to extract the files that it holds:
    cat Blah.tar | tar xfv -
    will work. Usually, the file is compressed so I do:
    zcat Blah.tar.Z | tar xfv -
    Good luck.
    Pss..TROSSIN,
    I also downloaded a .TAR file, but I don't know what to have in order for me to extract the .TAR file. I know about WINrar, but I have a MAC OS/X...I have the UNrar, but it's not working at all for me...So, do you know where I can get an "extracter" (sorry, I don't know the term for those programs that extract files)?
    Thanks.
    -GG
    Please post mac questions in our mac forum. I'm moving your post to the mac forum.
  3. Explorer Case's Avatar
    Mac OS X (10.3+) built-in archiver app (BOMArchivehelper) will work on .tar files
    (and also .bom, .bz, .bz2, .cpgz, .cpio, .gzip, .gz, .tgz, .tbz, .tbz2, .Z, .zip).
    And a lot of 3rd party apps do .tar as well, which you can find on VersionTracker or MacUpdate: e.g.
    - The Unarchiver
    - StuffIt DeLuxe/Expander
    - 7zX
  1. Replies: 6
    Last Post: 8th Apr 2010, 18:57
  2. Frameserve on MacOS??
    By Maxwellbest in forum Mac
    Last Post: 4th Oct 2008, 16:34
  3. Replies: 2
    Last Post: 8th Nov 2007, 07:55
  4. Replies: 4
    Last Post: 19th Oct 2007, 16:32
  5. How to extract a .wmv file from inside a .dat file
    By Toastie in forum Video Conversion
    Last Post: 17th Jun 2007, 22:06
