This is what I want to do: I have a mkv file on 100 MB, and I want to encode it to XviD with about half the bitrate. (Source bitrate is 6700 kbit/s)
This is what I type in commando prompt:
When the encode completes I have an incomplete file. If I omit to include bitrate=3500 I get a brilliant encode, but the same file size and bitrate (which i wanted to cut in half) as the source.
Am I doing anything wrong or is it just not possible?
Thread: Problem: mencoder - mkv to avi
Your source is 2 min long?
Where did you get info from?
What's in the mkv?
Your command is wrong if you're not going to follow with a second pass.
Bitrate setting will be ingored.
By the way you need a seperator between options.
So in the end you'd drop bitrate for pass 1, and for pass 2 you'd type
pass=2:bitrate=3700
Just drop pass=1 flag for a one pass encode.
If bitrate was not to work as preferred you could mess with fixed_quant.
gl
How to convert MKV to AVI or OGM to AVI using mencoder
By Baldrick in forum User guidesReplies: 74Last Post: 19th Dec 2010, 09:54 -
Mencoder MKV to Xvid problem
By midders in forum Video ConversionReplies: 2Last Post: 28th Nov 2009, 18:34 -
Seeking expert advice - Mkv to AVI + Subs (Mencoder)
By izzy2k in forum Video ConversionReplies: 2Last Post: 7th Apr 2009, 09:28 -
mencoder, convert mkv to avi + ac3. sound issues
By clavain in forum Video ConversionReplies: 1Last Post: 29th Jan 2008, 17:02 -
Converting MKV to AVI With Mencoder
By Startropic1 in forum Video ConversionReplies: 16Last Post: 25th May 2007, 18:03
Statistics
Newest guides
Latest tool updates
New media comments
