VideoHelp.com Forum
    I have used ffmpegX to encode a two hour 720x480 miniDV quicktime into an mpeg2 using the ffmpegX encode setting to burn onto a 4GB DVD. When I playback the DVD there is a flicker in the scenes.
    What is causing this? Is it bad encoding - the fact that it is two hours of full resolution compressed into mpeg no larger than 4GB? Can I do anything to fix it or prevent it from happening again? Does it have anything to do with keyframing at certain rates or not keyframing?
    Any ideas???
  2. Member exekutive's Avatar
    If the source framerate is 23.97 you need to use DVD mpeg2enc and check the "Set 3:2" box under options.
    That's the strange thing - the source framerate is 29.97 aspect ratio 4:3. It was recorded in regular dv with a Panasonic AG-DVX100B (it might be the model prior to this one but that should make too much of a difference, should it?). There is no progressive option on this camera and so therefore no need for pulldown, right?
    I just don't get it. Maybe I check something I shouldn't in ffmpegX? I really have no clue? Any suggestions. I'm willing to try them as I have a July 5th deadline and have to create a DVD from the two hours of full resolution (720x480 interlaced) video I have.
    Could it have anything to do with de-interlacing the video in FCP 5?
    Still wondering...
  4. Member exekutive's Avatar
    Why aren't you using iDVD or DVD studio to author your FCP project to a DVD?
  1. How to choose *separate* videos off one DVD for encoding in ffMPEGx
    By DrLooby in forum Newbie / General discussions
    Last Post: 20th Aug 2011, 21:13
  2. ffmpegX not encoding properly -- fails after 7%
    By larrryc in forum ffmpegX general discussion
    Last Post: 22nd Apr 2010, 14:07
  3. Help Needed: DVD to one DVD-R using ffmpegX without re-encoding
    By DDieggo1000 in forum ffmpegX general discussion
    Last Post: 23rd Jun 2009, 22:00
  4. Strange flicker on my DVD-Rs
    By ministry88 in forum DVD & Blu-ray Recorders
    Last Post: 6th Mar 2009, 22:43
  5. (some) MOV's not encoding to MP4 on ffmpegX
    By DarkPhoenix77 in forum Mac
    Last Post: 6th Oct 2007, 23:35
