Hello,
I've got a problem when I encode an avi file to mp4 with MeGui.
I think the problem is with avisynth because the problem is the same when I encode with xvid, but it'm not sure at all.
The encoding finish well but when I play the mp4, some parts of the file was cut. And at the place of the lacking parts there're the film that repeats itself.
I uploaded a exemple of video files there : http://dl.free.fr/b3KUSklGp/avi_mp4.7z (12mb)
You'll find a cut of the avi I'm trying to convert to mp4, and the mp4 I get after the encoding.
Very strange isn't it ?
All the options I choosed in MeGui are thoses by default. I'm using the lastest version 0.2.4.1041.
Config
Vista 32bit
Core 2 Duo 4300
2gb ram
ATI X1900GT
Thanks for your help
Sekaiji
Thread: avi to mp4 with MeGui prob...
And the avisynth script is?
yes it is strange
the sample seems to be in a continuous 4 sec loop
Thank you for your answer, I just finally found a solution.
In the avisynth script I add "convertfps=true" and now there's not anymore loop.
It works !
Sekaiji
prob megui with win 7 T.T
By lainexperiments in forum User guidesReplies: 8Last Post: 30th Jul 2010, 04:00 -
Encoding MP4 in MeGui
By sanosuke in forum Video ConversionReplies: 6Last Post: 9th May 2010, 08:10 -
MEGUI MP4 to AVI XviD Error
By DruidCtba in forum Video ConversionReplies: 22Last Post: 6th Nov 2009, 14:35 -
Problem with Wall-e Bluray to MP4 with MeGUI
By 8ball79 in forum Blu-ray RippingReplies: 7Last Post: 21st Jun 2009, 07:59 -
DirectShowSource prob for AVI(DV) to MP4
By sekaiji in forum Video ConversionReplies: 3Last Post: 29th Jun 2007, 18:43
Statistics
Newest guides
Latest tool updates
New media comments
