VideoHelp.com Forum
Results 1 to 9 of 9
    Hi, I'm currently writing my diploma thesis.
    It's about cutting OpenDML AVI Files in Java.
    However, my question is:
    how can i calculate the size of JUNK chunks in an AVI File?
    May the field PaddingGranularity help in that case?
    Here's a part of the avi's structure in xml-representation (I've written a tool, that extracts the metadata to a xml file).
    <RIFF_AVI>
              Pos: 0
              id: RIFF whole chunk-length: 1884630016
              content length: 1884630008
              Format: AVI
              <LIST_hdrl>
                         Pos: 12
                         whole chunk-length: 17112
                         content length: 17104
                         List-chunk-type: hdrl
                         <_avih_chunk>
                                      Pos: 24
                                      whole chunk-length: 64
                                      content length: 56
                                      chunk has subchunks: false
                                      MicroSecPerFrame: 40000
                                      MaxBytesPerSec: 3788800
                                      PaddingGranularity: 512
                                      Flags: AVIF_HASINDEX, AVIF_MUSTUSEINDEX,
                                      TotalFrames: 12514
                                      InitialFrames: 0
                                      Streams: 1
                                      SuggestedBufferSize: 151552
                                      Width: 720 Height: 576 Scale: 0 Rate: 0
                                      Start: 0 Length: 0
                          </_avih_chunk>
                          <LIST_strl/>
                                      Pos: 88
                                      whole chunk-length: 16720
                                      content length: 16712
                                      SOME OTHER CHUNKS
                          </LIST_strl>
                          <_vprp_chunk>
                                       Pos: 16808
                                       whole chunk-length: 48
                                       content length: 40
                          </_vprp_chunk>
                          <LIST_odml>
                                     Pos: 16856
                                     whole chunk-length: 268
                                     content length: 260
                          </LIST_odml>
              </LIST_hdrl>
              <LIST_INFO>
                         Pos: 17124
                         whole chunk-length: 44
                         content length: 36
              </LIST_INFO>
              <_JUNK_chunk>
                           Pos: 17168
                           whole chunk-length: 48356
                           content length: 48348
              </_JUNK_chunk>
              <LIST_movi>
                         Pos: 65524
                         whole chunk-length: 1884363788
                         content length: 1884363780
                         List-chunk-type: movi
              </LIST_movi>
              <idx1_chunk>
                           AviIndexChunkPos: 1884429312
                           whole chunk-length: 200232
                           content length: 200224
              </idx1_chunk>
              <_JUNK_chunk>
                           Pos: 1884629544
                           whole chunk-length: 472
                           content length: 464
              </_JUNK_chunk>
    </RIFF_AVI>
    Isn't it the same as every other chunk in an AVI file? You have a 4 byte identifier ("JUNK"), a four byte length field (little endian), and then data of the length indicated by the length field. The full chunk is therefore the 4 + 4 + length.
    @ jagabo: Thanks for the quick reply, but what I intetially mean is a bit different:
    One of the JUNK chunks in my example has the following structure:
    <_JUNK_chunk>
    Pos: 1884629544
    content length: 464
    </_JUNK_chunk>
    It is on position 1884629544 and has the size 472, but why? Why doesn't it have a different size?
    There must be a mathematical formula, how the encoding algorithm places the JUNK chunks.
    I know, that this JUNKS are used for alignment, but on what bounds?
    In this case the JUNK causes a block size of: POS + JUNKSIZE = 1884629544 + 472 = 1884630016 byte.
    In this case the blocksize / PaddingGranularity = 1884630016 / 512 = 3680918 -> fills the blocksize to next 512 package, but o the other JUNK in my example:
    <_JUNK_chunk>
    Pos: 17168
    </_JUNK_chunk>
    Blocksize is: POS + JUNKSIZE = 17168 + 48356 = 65524
    But 65524/512 = 127,9765625 -> does not fit any blocksize! So why was this chunk placed on that position with this size?
  4. Member Cornucopia's Avatar
    I don't program much, but I though [POS] just meant starting position. If true, it would have no bearing on the blocksize. Only the [JUNKSIZE] should.
    So,
    472 / 512 (mod) = 1 block
    48356 / 512 (mod) = 95 blocks
    Correct me if I'm wrong.
    So,
    In my opinion, JUNK chunks are only added, if the creator of the video (the encoder) wants the previous written data to align on a certain block size, so the position is important, I think.
    In my last example there was 17168 bytes (chunks + data) written to the file and the encoder added on position 17168 a JUNK chunk of size: 48356 to achieve, that the next chunk begins on position: 65524
    And I don't understand, why on that position? The size of that JUNK chunk makes to me no sense!
    I think the reason for the size of the first JUNK chunk was to align the first subchunk in the movi chunk on a block boundary (12 more bytes would put it in the right place, 65536). I just examined several AVI file and they all start the movi chunk on a 512 byte block boundary, not the subchunks.
    I don't know if PaddingGranularity defines the block size. I believe 2048 is used a lot because that's the sector size used on CD/DVD.
    @jagabo: Thanks for your reply.
    I think, that I have the reason!
    The size of the LIST('movi') chunk's fields is 12 byte (4 byte fourCC, 4 byte size, 4 byte type)! 65524 + 12 = 65536. In that way the subchunks of the movi chunk are aligned on that offset. But why 65536? Ok thats 2^16, but why this data is aligned on that size?
    There's no info in the header, that says, that the block should be 65536 bytes long, correct me if I'm wrong.
    This information is for me very important, because I'm developing an algorithm, that soft-cuts an I-Frame-only avi-file by predicting the positions of each frame in the file (without using index chunks (except of the superindex)), and these JUNK chunks are a thorn in my side !
  8. @ maestro777
    A while back, I made an experimental avi writer tool (just saved an RGB bitmap to an RAW
    avi container for simplicity sake) to see and understand how they are put together. I can
    say, I still am confused in some aspects. But, I did find a few things out in my searching.
    For one, I found that sometimes, the JUNK is used to as -- to write junk inside the AVI
    container. I seen where *other* avi editors suites do this.. ie, ULead and a few others,
    where they wrote their "signature" name inside the JUNK area, usually at the top. I think
    this is usually understood as the "versioning" or branding aspects.
    And, two, sometimes we don't know *why* a given avi editor will include a JUNK inside
    an avi file it creates. I wrote several [x,y] demension RGB -> AVI in VirtualDub-MPEG2
    and seen it write JUNK -- from 8x8 to 64x64 to 352x480, etc. So, we may never know
    for sure *why* they do, but they do -- possibly for their own propriatory purposes.
    -vhelp 4322
    VHELP's - Sample Clips [last: 12.29.06],
    my YouTube videos
    @vhelp thank you for your answer.
    Looks like, I have to find a different way for my cutting-strategy.
    In my test video, the JUNK chunks don't have any metadata, only zero-values.
  1. Help plz. :Capture AVI issue : Bad chunk in frame data: Invalid length
    By chindoo in forum Newbie / General discussions
    Last Post: 3rd Jul 2011, 19:51
  2. Mpg : Mpeg video size and bitrate calculation
    By Bonie81 in forum Programming
    Last Post: 21st Jun 2011, 22:38
  3. Avi chunk viewer?- what is this?!
    By vanjo in forum Software Playing
    Last Post: 29th Oct 2010, 02:20
  4. overscan calculation
    By cd090580 in forum Newbie / General discussions
    Last Post: 2nd Jan 2008, 07:14
  5. avi chunk viewer
    By agent222 in forum Video Conversion
    Last Post: 15th Nov 2007, 10:03
