I need to edit some audios, But I cant hear the audio well from my PC speakers since I have a loud fan, I would like to know where and wich Headphones to buy. Im going to be editing audio for long hours so I would like some confortable headphones but with good quality sound.
Thanks!
Just about any headphones with a 1/8" plug (3.5mm, I think) would work. Many come with a 1/4" plug and a adapter to 1/8". It comes down to how much you want to spend. Some good brands:
http://www.sennheiserusa.com/newsite/
http://www.koss.com/
There's lots more. I prefer the over-the-head type instead of 'ear buds'. The ones with the cushioned smooth ear pieces seem to be more comfortable than the ones with just foam if you plan to wear them for an extended time.
You would just plug them into your line out on your computer, usually the green jack, the same as your speakers use. You can also pick up a switch box or just a extension cable to make it easier to change from head phones to your speakers.
For where to buy them, just do a Google search when you find a model you like and check prices and shipping to your region.
Thanks a lot my friend
Look up the words "Grado Headphones" . Those are considered the best for the $, and they are priced low, compared to many other brands.
http://www.productwiki.com/grado-sr80/
Also, go to a store and wear some big headphones around for 10 minutes. If it is too uncomfortable or sweaty, consider the open style models which are lighter but not as good sounding in the bass response.
I would'n use ANY headphones as a sound monitor. Especially at frequency equalizing the results would be disappointing. Better find a way of connecting to your stationary audio system.
forum post attachments disallowed
By davexnet in forum FeedbackReplies: 2Last Post: 18th Nov 2010, 17:42 -
How I modify in forum archive my old post?
By roma_turok in forum FeedbackReplies: 6Last Post: 17th Jun 2010, 09:35 -
Is it possible to embed flash video into forum post? [Solved=Yes you can!]
By freebird73717 in forum FeedbackReplies: 15Last Post: 7th Mar 2009, 11:36 -
How to create a forum that allow to record webcam and post video messages?
By deafeagle in forum Newbie / General discussionsReplies: 2Last Post: 27th Dec 2007, 13:03 -
What forum should I post in?
By ne_plus_ultra_1 in forum FeedbackReplies: 1Last Post: 3rd Sep 2007, 11:54
