I just bought a Canon HV20 which records HDV in MPEG2. If I only had 20 minutes of video, why couldn't I burn it to a regular DVD? I'm assuming a regular DVD player wouldn't be able to play it back, unless the CODEC was hacked or upgraded to recognize HD. Anyone have any ideas? I really don't want to drop $1000 or more on HD DVD or Blueray just now.
DVD players do not play high definition anything. You have to convert to standard definition MPEG2 for normal DVD players.
Options are limited
1 Buy HD DVD player and author to DVD-5 or DVD-9
2 Buy one the Divx-HD certified players and encode divx,xvid,wmv, etc.
http://www.divx.com/products/hw/browse.php?c=7
3 Play from a computer
4 Play from a server of some sort
5 Wait for a HD/BD recording player.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Are you saying one can author in HD, burn to a DVD-5 or 9 disc and have it playback in true HD on a HDDVD or Bluray player? If so any idea how many minutes of video will a standard dvd (5 or 9) hold?Originally Posted by edDV
Thanks...
As always it depends on the bitrate. If you do not do any recompression you can fit 20 minutes of HDV format as HD-DVD on a DVD-5 disc or 35 minutes on DVD-9.
But HD-DVD can use VC-1 or h.264 as alternative to MPEG-2 to gain more compression but then I do not think there are any easy authoring software available at the consumer level yet.
Check this guide how to create HD-DVD in MPEG-2 format on DVD-R discs (3X DVD):
http://www.avsforum.com/avs-vb/showthread.php?t=705146
The MPeg2 DVD 5/9 to HD DVD player authoring is supported in ULead Movie Factory 5 (if detail instructions are followed) but I haven't yet seen a success story (with procedure) for VC-1 or h.264 to DVD 5/9. Maybe it has been done but is not yet mainstream.
just wondering - can normal dvd player hack to play hd-dvd
By chanra in forum Newbie / General discussionsReplies: 16Last Post: 12th May 2009, 22:00 -
burn RMVB file to DVD to play on standard DVD player
By samoyed in forum Newbie / General discussionsReplies: 8Last Post: 14th Mar 2009, 21:29 -
Why can I not burn DVDs that play in my standalone DVD player?
By bmoreravyns in forum Authoring (DVD)Replies: 12Last Post: 18th Sep 2008, 14:05 -
How to burn RMVB files to DVD so it will play on regular DVD player
By MithrasX16 in forum Newbie / General discussionsReplies: 2Last Post: 24th Oct 2007, 05:53 -
Can you burn Xvid files to DVD so they will play on stand alone DVD Player?
By JoeBolden in forum Newbie / General discussionsReplies: 4Last Post: 3rd Aug 2007, 16:48
