VideoHelp.com Forum
    Vista computer with Windows media apps plus VLC.
    I need to embed an .mpg clip into a narrated PowerPoint, but there's audio in the clip that interferes with the narration.
    I have almost zero skill (actually negative, if you figure the errors I make).
    What can I do to strip that audio from the clip?
    Thanks,
    Sylvia
    You should be able to do it with Windows Movie Maker...
    open the mpg and delete the audio then re-save and add it to the powerpoint.
    HERE TO HELP
    Ollie.
  3. Member yoda313's Avatar
    Your other option is virtualdubmod or virtualdubmpeg2. You can go to streams after you open the file and save the audio as a wav file. From there you can do whatever you want with it since wav is such a univeral audio format.
    Great - done - thanks!
  5. Member Cornucopia's Avatar
    You'd save quality if you just demuxed to A+V elementary streams, and then remuxed only the Video stream--No Reencoding, no loss (unlike the WMM method). You could use TMPGEnc, Imago, Muxman(?), others
  1. Remove 5sec out of video clip
    By rudokino in forum Editing
    Last Post: 10th Oct 2010, 00:25
  2. need help on how to crop/edit with mpg stream clip
    By mike300 in forum Software Playing
    Last Post: 12th Jun 2010, 18:48
  3. remove audio part of mpg
    By zmartha in forum Audio
    Last Post: 19th Oct 2009, 18:51
  4. How do I edit audio in an MPG clip
    By JackPollack in forum Editing
    Last Post: 17th Sep 2007, 20:00
  5. Replies: 1
    Last Post: 6th May 2007, 17:52
