Good morning everyone
I'm having a little problem in setting up XP Home and User Accounts with diff. hardware.
Ok. Let me explain.. It was my assumption that when you create addition User Accounts,
(with different hardware.. ie, PCI/USB capture cards) that *ONLY* the user account
associated with that hardware (installed at the time of the new user account) would
be available to the user in that account.
Given the following User Accounts:
A - Hauppauge HVR-1600 capture
B - ADS VideoXpress USB2 capture
C - Hauppague PVR-USB2 capture
D - Winfast TV2000 XP Expert capture
D1-Winfast TV2000 XP Expert capture (mod Setup or Registry)
E - Video Workstation
Then:
If I want to capture only with the Winfast, (D) then XP Home should only see the
Winfast and not the others.
If I want to capture with the HVR-1600, (E) again, then XP Home should only see
the HVR-1600 and not the others.
As of current, everything that I have added (associated to *each* his account) is
showing up in *ALL* the accounts. All the capture cards/devices are showing. I
might (would like) to make other configurations using the same capture cards,
maybe to Fine-Tune or Debug their performances, etc. But I can't do this at
this time.
Q: If this can't be done the way I'm currently doing, above, then is there another way
that I can acomplish this ??
A: TBD
-vhelp 4304
OK... there is a shared folder to be accessed by all accounts at My Computer\Shared Docs
however as i understand if you are logged in as Account A any program, file created should only be accesses by A (as long as it isnt put into the shared documents folder)
however... any devices or hardware introduced
eg. Networking Adapter, USB Memory Stick, External HardDrive.... basically anything external camera.. it doesn't matter will be open to all users.
I don't think there is a way round that.HERE TO HELP
Ollie.
Reliable USB capture devices?
By slats7 in forum CapturingReplies: 21Last Post: 11th Mar 2012, 19:32 -
Control Panel --> User Accounts, NOT SHOWING/WORKING. Help!
By UmmAddan in forum ComputerReplies: 6Last Post: 21st Aug 2010, 08:33 -
USB capture devices vs USB tuner devices...... which are better for recording?
By True Colors in forum Video StreamingReplies: 1Last Post: 31st Jan 2010, 15:04 -
usb devices on a network
By lordhutt in forum ComputerReplies: 6Last Post: 6th Jul 2007, 21:49 -
XP User Accounts
By Lucifers_Ghost in forum ComputerReplies: 8Last Post: 24th May 2007, 14:27
Statistics
Newest guides
Latest tool updates
New media comments
