In the profile under
Member Status Member
you can change what it says... I presume this is not meant to be like this... maybe it is I don't know but I change mine by deleting it and rewriting to Genious...
I don't really understand the member status bit... is it meant to go up by the amount of posts you make? That or not I don't think your meant to be able to change it yourself!
Results 1 to 15 of 15
Thread: Member Status......doesnt work
HERE TO HELP
Ollie.
oh ok i did some more looking.... am i right that you are meant to be able to change it?
HERE TO HELP
Ollie.
IIRC it used to be after a certain number of posts it became editable. I don't know if it's still that way or not.
Buy My Books
Well I joined yesterday and i can change it.... ive made quite a lot of posts i wouldnt have thought it would have been enough though
HERE TO HELP
Ollie.
You're a genious, figure it out yourself. :P
I believe it used to be fifty posts before you could change it yourself but I guess that must have changed. A lot of forums use that for member status and rankings but on this forum it's meaningless unless it's the text is light blue which would indicate a mod.
ok thanks
HERE TO HELP
Ollie.
BTW, it's spelled Genius.
I never point out spelling mistakes but that was too hard to pass up.
yer i considerd that but i thought there was an o........
HERE TO HELP
Ollie.
I have removed the 50 post limit before you could change the status...but I can't remember when or why...
ok...
is anything limited like to be a moderator or is it just your decision?HERE TO HELP
Ollie.
Hey Baldrick, how come your status line is barely distinguishable from anyone elses? Shouldn't it be written in lights or something or would that conflict with your natural modesty?Originally Posted by Baldrick
I tried to change mine to £12, but it didn't work. Then I tried "Administrator", but that didn't work either. But when I changed it to Yes, it was ok.
Baldrick's status line is dark blue. To differentiate him from us lowly Mods in just blue.
But it's hard to tell with some backgrounds.
As a Mod you get some bonuses, like a 24/7 work schedule and no pay. It's like my present job.
Admin,administrator and moderator and special characters doesn't work.Originally Posted by 12Quidkidinnit
I can't remember a date, but it was part of a major overhaul that included the removal of post count from the member status area and the "hiding" of the reported posts. Seems that things were getting a bit out of hand at that time.Originally Posted by BaldrickUsually long gone and forgotten
USB AVCHD for ps3 doesnt work
By caner12 in forum Video ConversionReplies: 2Last Post: 10th Aug 2009, 15:28 -
Remove WGA 1.2 doesnt work
By jyeh74 in forum Newbie / General discussionsReplies: 5Last Post: 6th Mar 2009, 23:46 -
Encoding ( hardsubbing) doesnt work with ffdshow
By lovemusic in forum SubtitleReplies: 2Last Post: 5th Mar 2008, 14:37 -
Some audio doesnt work
By TheEmperor in forum AudioReplies: 2Last Post: 16th Aug 2007, 09:05
