VideoHelp.com Forum
Results 1 to 13 of 13
    I have a VIDEO_TS file that playes w DVD player.
    its not a copyright issue. it have several chapters. a few have sound and the rest don't seem to.
    Id very much like to findout with some other program if the 'soundless'tracks had sound that can somehow be recovered with a conversion
    any ideas?
    much appreciated!
    cheers
    MPro 2.66 3GB RAM 1.5TB HD's
    MigliaMiniHD
    QTPro, MPEG2 add on MPlayerX2
    MPEG Streamclip
    24 + 21" samsung flat panels
    G4dual 2GB
    AlchemyDVR card
    some further information:
    I used yade X (french version unfortunately, and my french is Menu Restricted Food menu that is!)
    I extrated two files: a tlp2-00.m2v this seems to be the video of one track
    t1p2-00-en.ac3 this seems to be the audio. VLC player plays this.
    so why does DVD player not play this audio?
    is there a way to recombine the two above to get a QT file that plays 'in the usual fashion/"
    much appreciated as these file are important!
    cheers
    MigliaMiniHD
    MPEG Streamclip
    G4dual 2GB
    AlchemyDVR card
    There is a known problem playing back certain ac3 files on Intel macs.
    http://docs.info.apple.com/article.html?artnum=304086
  4. Explorer Case's Avatar
    "This issue does not occur in Standard Definition DVD projects." - Only HD DVD projects, so I don't think that issue applies here.
    DVD Player expects a VIDEO_TS folder, not the separate
    M2V and AC3 files. You can use QuickTime (if it has the
    AC52 Codec) to combine them: Put them in the same folder
    with the same name (but different extensions obviously)
    and double-click the M2V file. If that doesn't do it, convert
    the AC3 to AIFF -- I know that works.
    Al Bloom
    putting the two in one folder did not work. opening the .m2v in QT still had no sound. how can I tell if I have the AC52 Codec you mentioned?
    how do I convert the .ac3 into AIFF?
    cheers and thanks
    MigliaMiniHD
    MPEG Streamclip
    G4dual 2GB
    AlchemyDVR card
    An .m2v file is the pure video component of the movie, so it will contain no sound by design.
    The ac3 file is the audio stream. You've already indicated that VLC plays it fine.
    You can use many tools to convert audio from one format to another. Ffmpegx should happily do so. If VLC will play your audio fine, but you still have trouble, it may indeed be worthwhile converting into another format (AIFF is one possibility; MP2 is another).
    After creating the new audio stream, remux with the .m2v file and re-author as DVD. Then try playing the resulting VIDEO_TS folder.
    But a more basic question is, have you investigated why some chapters have sound, and others don't? Did you look at the Info (from QT or VLC, say) for those chapters to see what, if anything, is different about them? And did you look for other audio tracks? Sometimes, the audio is on, say, Track 1, and sometimes on others (for different languages, typically, but maybe the disc was carelessly authored, and the audio was randomly assigned to different tracks).
    Sound Converter will do it for $10
    http://www.dekorte.com/projects/shar...oundConverter/
    Al Bloom
    again thanks for all these tips. Id forgotten about ffmepgX and have been playing with that.
    I extracted the individual VOBs from YadeX
    two palyed fine in QT. I can't find any difference in the QT info on those w sound and those w/o
    I dropped a VOB into FFmpegx and created a Divix.avi. that QT file plays fine. I have to fiddle to get the size of the image correct but at least this does the job, although I ahve to do them one at a time.
    no longer a DVD but a series of QT files which is OK w me.
    cheers and thanks again.
    MigliaMiniHD
    MPEG Streamclip
    G4dual 2GB
    AlchemyDVR card
    You can drop the QTs onto Toast (7+) and have it make a DVD
    for you (real or disk image). Each QT would be a chapter that
    you'd be able to make a menu entry for.
    Or you could fork out $23 for VisualHub and tell it to concatenate
    the QTs if you want a single DVD file. VH will even burn it for you.
    Al Bloom
    WoW
    din't know this about toast I have T 7 and 8 don't use 8 as of now hve no Blu-Ray!
    my VOB's number 14. Id love to make a functional DVD
    should I put the 'new' .avi's from FF into toast?
    pls let me now as Id like to try this
    cheers ande thanks agagin!
    MigliaMiniHD
    MPEG Streamclip
    G4dual 2GB
    AlchemyDVR card
    I haven't done Blue-Ray or other HD either. Just got a great
    honking 47" Sony for F-word day, and we have all of 10 HD
    channels here in the far boonies of southwestern Virginia.
    And copying those HD's to my DVD recorder STILL gives me
    nothing but a letterbox. Snarl.
    But I digress. In Toast (7+) select DVD Video. Drag your QT's
    into its window. Reorder as needed. Choose a menu style (I
    always take "corporate" because I'm anal), hi-lite each to edit
    the title and even pick a frame to show as the button's picture,
    leave "chapters" at zero lest you get sub-buttons which bore
    me to death. Burn.
    AVIs might work as well as, or better than, QTs. Try it. Use
    Toast's file/save to disk image so you don't blow all of $0.32
    on a physical disc. And writing to your HD is faster than writing
    to a disc. You can come back later to burn a disc.
    If you double-click that image, it'll launch DVD Player (if your
    prefs say so), and you can see real quick what you got.
    Try it. You may well hate your first couple attempts, so going
    the disc image route will make you feel better.
    Go for it.
    Al Bloom
    Well How curious is this: two of the original VOB's had sound but were small 320 x 240
    the ones w/o sound were processes in FF to make somethng like 890 x 400. With sound!
    so I thought Id process the two w sound into larger files as above withthe same parameters
    = No Sound!
    I tried changing the track audio from 0 to 1 and then 2 and:
    Nadaa no sound!
    so I thought just use QT and export:
    No sound!
    how about that!
    MigliaMiniHD
    MPEG Streamclip
    G4dual 2GB
    AlchemyDVR card
  1. Replies: 9
    Last Post: 13th Jan 2010, 21:15
  2. partial subtitles
    By shredcaster in forum Subtitle
    Last Post: 2nd Jul 2009, 08:41
  3. Video Partial View
    By wonstep in forum Software Playing
    Last Post: 29th Apr 2009, 22:04
  4. No sound when converting DVD (VIDEO_TS)
    By jompa in forum ffmpegX general discussion
    Last Post: 18th Oct 2007, 16:48
  5. partial encode
    By wkmanley in forum ffmpegX general discussion
    Last Post: 9th Oct 2007, 14:43
