how do you change aspect ratio of a video using an avs script.
thanks.
Thread: change aspect ratio
Do you want to re-encode it ? If so, it is simply a metter of resizing the video correctly.
If you are talking about changing the aspect ratio flags in the video itself, then avisynth is the wrong tool.
For mpeg-2 video, use Restream. For mpeg4 based avi files (Divx/Xvid) try mpeg4modifer.
Note : not all codecs using the avi container use or honor the AR flags, and not all players read them correctly or at all.
Change Aspect Ratio
By wulf109 in forum DVD RippingReplies: 1Last Post: 7th Feb 2011, 18:12 -
Best way to change aspect ratio....
By Han Solo1 in forum Video ConversionReplies: 13Last Post: 14th Oct 2010, 10:33 -
Aspect Ratio Change
By VicSedition in forum Video ConversionReplies: 9Last Post: 17th Feb 2010, 11:01 -
Have to change the aspect ratio - what is the right way??
By Weef in forum RestorationReplies: 25Last Post: 4th Mar 2009, 13:14 -
How to change aspect ratio?
By crt in forum Video ConversionReplies: 2Last Post: 9th Oct 2008, 10:49
Statistics
Newest guides
Latest tool updates
New media comments
