I am lookin at investing in a faster CDR/RW burner. Could anyone tell whether i should go with SCSI or IDE. I currently have a SCSI burner but am wondering what the differences between the two are, and whether i really need to fork out the extra $$$ for a SCSI or if IDE will suffice.
Thanx
most ppl say somethin smart or profound here.......... I won't
I don't believe it's worth for a home user to spend money on a SCSI, it is more for Work Environment with lots of disk load, IDE drives are nearly as fast, and CD/DVD drives are exactly as fast for the regular work, only if you are on a network and you plan on having multiple access, then consider SCSI
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician.
Thanx Sefy. What do you think is the current best brand burner to buy? I was only wondering about SCSI drives cause i do a lot of burning on the fly and have been told that SCSI is more reliable seeing as it doesnt rely on CPU power. I am looking for a moderately priced 24x writer. Any suggestions?
Thanxmost ppl say somethin smart or profound here.......... I won't
Well, if you want a great and cheap, then go get a Lite-On 24x10x40, they cost around 70$, and officialy support upto 99min CDR media
If you want "old reliable" you can get the more expensive Plextor 24x10x40, they can cost over a 100$, and only support (and not officialy) a bit over 90min CDR media.Email me for faster replies!
Best Regards,
Sefy Levy,
Thanx again Sefy, I will look into the LiteOn a bit further
Best IDE Burner for burning Dual Layer or Single Layer Discs for Duplicator
By Konfusion in forum DVD & Blu-ray WritersReplies: 7Last Post: 18th Nov 2011, 03:16 -
Looking to get a new IDE burner
By moonhoney2 in forum DVD & Blu-ray WritersReplies: 5Last Post: 29th Oct 2009, 10:23 -
Pioneer DVR-118L internal IDE Burner ???
By blinky88 in forum DVD & Blu-ray WritersReplies: 1Last Post: 26th Sep 2009, 17:07 -
ide dvd burner and sata harddrive - how do i configure?
By mshuang in forum DVD & Blu-ray WritersReplies: 2Last Post: 12th Dec 2007, 00:46 -
IDE DVD Burner VS SATA DVD Burner
By mn072065 in forum DVD & Blu-ray WritersReplies: 13Last Post: 13th Nov 2007, 20:15
