hi all this is my first time on this site. I installed a tv video card and ran coxial cable from satellite receiver to computer..I'm watching tv on my computer but when I try to record I get an error message "no data from the encoder unspecifed error ox80004005" I'm really new to this so can anyway help me? ..thks
Thread: wintv-HVR recording
So many problems with this post...
1) Wrong forum. You want the Capturing forum.
2) You make the usual newbie mistake of thinking that the less you tell us, the more likely you are to get help. You are wrong. The more you tell us about what you did, the more likely you are to get help. Try again IN THE CORRECT FORUM and include this information:
Your tv video card model
What software you are using to record
What format you are recording in (DVD, VCD, etc.)
Whether or not you can see the video through your tv card BEFORE you try to record it. Usually if you can't see it prior to recording, you're not going to capture anything when you try to record it.
My best guess based on your error is that the capture card is not seeing any video signal, hence there is nothing to record. If so, you'll need to fix that problem, but more info on exactly what you are doing would help.
I'd try reinstalling the Hauppauge software.
Are you talking about the HVR-1600? You might find some info in this thread.Originally Posted by brenjim
http://forum.videohelp.com/topic330091.html
As for a satellite receiver, the card has no specific support other than analog input.
Hauppauge WinTV-HVR 1850 Questions
By NMeade in forum CapturingReplies: 73Last Post: 18th Jul 2011, 10:16 -
Sky+ and WinTV-HVR 900H
By jubbely2 in forum CapturingReplies: 0Last Post: 15th Aug 2010, 07:14 -
WinTV-HVR-2250 TV Tuner
By Richintx in forum CapturingReplies: 18Last Post: 22nd Mar 2010, 23:36 -
Hauppauge WinTV-HVR-950Q
By mauiwowi in forum CapturingReplies: 1Last Post: 28th Aug 2009, 21:43 -
Hauppauge WinTV HVR-1800 Jerky unless recording
By michaeldg1 in forum DVB / HDTVReplies: 4Last Post: 6th Apr 2009, 15:10
Statistics
Newest guides
Latest tool updates
New media comments
